SAMSUNG LE40A558P3FXXU 40'' LCD TV
I was playing on my xbox through hd cables and the screen went static an then black, saying no signal, now i cant play the dvd player eaither, through scart or hd
  • 121 Answers
SOURCE: Samsung 40" LCD 1080p
Yes, it's not uncommon. It also depends a bit on the TV. Some are better than others. There is a connection between price and quality, although it is not absolute. What kind of equipment are you using? DVD, satelite tuner etc, and how is it connected? (scart etc)
Colors can be adjusted from the menus (se your manual for reference). I've never seen a TV that don't need color adjusting before it gets good, as color experience will vary with room coloring and light, etc.
Posted on Dec 05, 2007
SOURCE: Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Posted on Jun 05, 2008
Agent Aaron
  • 265 Answers
SOURCE: Samsung lcd hdtv won't receive signal from fios hd receiver
Hey nothingsfree,
You may not necessarily have anything incorrectly set up, but there are a couple of things that I would suggest trying.
First, you'll want to make sure that your TV is set to the correct input source. Some TV's will require that the input source be changed in order to display any signals from an external device, like your HD-DVR. This can typically be done by accessing the main video menu using your remote control.
According to information provided by the manufacturer, you should be able to change the input source for this model TV (Samsung LN46A750) by doing the following:
* Press the "Menu" button on your remote control
* Press the "Up" or "Down" arrow button to select "Input," then press "Enter"
* Press "Enter" to edit the "Source List"
* Highlight the signal source for the HD-DVR, and press "Enter"
Next, you may want to try updating the TV's firmware. In some instances, simply updating a TV's programming can eliminate any potential hardware or software conflicts between two devices. To update the TV's firmware you will need access to a computer and a USB flash drive. Step-by-step instructions and the firmware update itself are available through the following website:
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN46A750R1F&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=02010100&disp_nm=LN46A750
Make sure to read all the warnings and disclaimers available though, as your TV may already have a more up-to-date firmware version than the one that can be obtained through Samsung's support page.
Should neither of these address the issue, you may wish to see if connecting your HD-DVR to a different HDMI input solves the problem. Much like computers, TV's have been occasionally known to have faulty inputs or loose internal connections.
If all else fails, I’d suggest contacting the manufacturer for further assistance. In many cases manufacturers are able to provide over-the-phone troubleshooting support, in addition to having access to a wider variety of possible remedies for hardware problems.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 23, 2008
VOTIT
  • 2071 Answers
SOURCE: Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
big_nash10
SOURCE: NO SIGNAL from DVD player
NO SIGNAL IN MY DVD 1080P7
Posted on Oct 18, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
I have 40? LCD Samsung flat screen TV model: LE40A557. This is 16 months old. Today the screen went blank and power indicator light blinks. I have switched the TV off and removed all equipments attached. I...
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Oct 17, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
The picture doesnt show but I hear the sound.
Don't worry the HD feed from the xbox 360 has a gain limiter
So the chances are more likely that either your Friends xbox has
the HD setting off or the TV has defaulted to standard video in.
If you get a black screen or a mesage that says no single .
But if your getting strange color on your set with the HD on
then we need to investigate this " Microsoft is liable!" for
damages caused by their console. Ill look in to this and
follow up. The xbox has broken connection under the poorly
soldered G.P.U. and will need to be re-flowed to the main
board to corrects this problem but that's a secondary priority
right now.
I'll check this out for you and follow up.
Rob
Oct 03, 2009 | Microsoft Xbox 360 Console
New Samsung 40" flat screen HDTV only plays in black and white
you need to check the cables.
component with RGB -- you need to connect exact match the color.
Feb 06, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung tv prob
My daughter's LCD which is barely used started showing horizontal coloured lines.I read that the LCD's are vunerable to static/charge build up and also power surges.
I unplugged my daughter's TV and it is now working properly however we now unplug the TV when it's not in use.
I was considering purchasing a larger model for the faily room but Not going to waste my money until they improve this rechnology.
Good luck to all.
Cheers!
Mar 22, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
307 people viewed this question
Top Televison & Video Experts
