Question about Jenn-Air Ovens
Replace plexiglass I can no longer find replacement part w10202023 can a piece of plexiglass be used for this replacement
Replacement thermostat for old GE oven
they say you can use a G.E. part# WB21X5320 in place of the WQB24X176 and supposedly it is available from Appliance Parts Warehouse Online
Oct 01, 2012 | Ovens
Iv brooken the white glass on my grill door can it be replaced by a glass provider or will i need to purchase a part from a apliance store.what is my cheapest option?
Yes, you can put a piece of tempered glass from a glass dealer in place of the original piece. The advantage is that you can use a heavier piece, if it'll fit. It might cost more to go that route, because it's a custom piece- they have to cut the glass before tempering it. Just call a couple of glass people and a couple of appliance people and go whichever route you find you prefer.
lp
Jan 11, 2011 | Magic Chef 9122 Gas Single Oven
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
Replace igniter part # 1990 in oven of model #3627332192
It's usually pretty simple. Start by turning power off to the oven - unplug it or disconnect power at the circuit breaker. Open oven door, remove all racks, then remove oven floor panel (it might be secured with two bolts or clips on the back side). Remove the flame spreader (one nut). Now you have the oven burner and igniter exposed. If the new plug differs from the old, cut off the plug and use ceramic wire nuts (should be supplied with igniter) to connect the wires. Don't shake the igniter - the coil is very fragile. Once the igniter is replaced make sure the wires are connected securely. Put everything back the way it was and test the oven.
Below are the two most popular oven igniters: flat bar igniter and round igniter.
Flat igniter - this is by far the most commonly used oven igniter. Includes all necessary pieces to replace longer ceramics. Size: 3-3/4" long. Fits Maytag, Whirlpool, KitchenAid, Magic Chef, Tappan, Jenn Air, GE (flat bar only), Sears Kenmore (flat bar only), even some Thermador cooktops and Viking ovens. - ff693fe.jpeg
Feb 25, 2010 | Kenmore Ovens
Glass in oven door cracked
The door glass can be replaced.
I would advise you not to use the oven until you get the glass replaced, as it can quite suddenly and without warning shatter into small pieces. thus causing further problems, and possibly injury.
Hope this helps.
Jan 31, 2010 | Whirlpool Ovens
The door no longer closes correctly leaving a gap at the top. When open it is no longer horizontal but falls to a downward slant
It sounds to me that the oven door hinges need to be replaced, especially if it is a drop down door
They need replacing as a pair.
There is no povision made for adjustment on hinges.
Hope this helps you.
Dec 08, 2009 | Miele H340-2 BP Pyrolytic Electric Single...
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Ovens Logo
42 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
