Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
Bizhub color registration - Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
My machine is showing me p-22 what does it mine
Color regist adjust failure
• The color shift amount is greater than the specified
range during main scan direction registration correction.
range during sub scan direction registration correction.
• On the color shift test pattern, the maximum and minimum
deviations detected in the main and sub scan
directions go over the predetermined value.
Dec 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Picking wrong color at printing
check that the two sensor that monitor the color registration on the transfer belt are clean, located under the transfer belt. need to remove the belt to get to them
Apr 03, 2014 | Konica Minolta Bizhub C253 Copier
Colour shifting error p21
color registration patterns not read correctly by sensors
Mar 18, 2014 | Konica Minolta bizhub C250 All-In-One...
Error p-28 konica c353
registration error have tech come out and run the proper registration procedure to align color to the black unit
Jan 09, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub c 250
Run stabilizer and gradation. Also check color registration.
Nov 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Colours are blurry
Registration problem, the color are not on top of each other looking blurrry. Service mode has a Regristration test that is run and can check registration
Jul 29, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
