Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Convergence problem with Toshiba TV 42H83
Yesterday my near 4 yrs old Toshiba 42H83 rear projection HDTV started having convergence problem all of sudden. The adjustment with the remote can move the red cross vertically, but not horizontally, which is what I need. What's worse, the red color deviation varies in direction in different area. In the center, it is offset to the right, while in the right hand side of the screen, it is offset to the left. I would like to know if it is easy to fix the problem myself, a guy with some basic knowledge of electronoic only. Since the projection TV now is out of favor, it doesn't make sense to spend 300~500 bucks to ask a professional to fix it. Any advice will be appreciated.;
  • 2 more comments
  • zodey Feb 26, 2008
    cant focus. cant line up plus symble. color is messed up at bottom
  • Tony Stone Jun 17, 2008
    in circumference menu red is way off on right side and wont adjust up/down
  • GregMSC Dec 03, 2008
    I have the 42H83 and my convergence is all messed up. I have been searching
    forums to find a fix and I am hoping this is the place. I would rather
    fix it myself rather then pay someone. Looks like I need to replace
    both the convergence IC's. I just need to know where to buy them and
    where in the TV they are located. Any additional tips would also be helpful.
  • Anonymous May 19, 2009
    I have the same problem a 42" Toshiba HD ready TV. However after replacing the ICs and one faulty cap the TV still has the same problem. One IC runs very hot. I checked all resisters and they are good. I don't know what else to check?
  • Toshiba Master
  • 3,459 Answers
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77ea520.jConvergence problem with Toshiba TV 42H83 - f0900cb.jpgh_mi
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 16, 2009
    Problem Solver:
  • 18 Answers
There are companies out there that offer convergence replacement boards - they swap your board for a rebuilt board. All U have to do is swap out hte boards. This is more costly than repairing it yourself but cheaper than a repair shop. U can also sometimes find your board on ebay. John
Posted on Aug 13, 2007
  • 398 Answers
There are 2 large black IC's called convergence outputs and one of them has failed. The IC's are usually the STK392-110's and a good rule is to go ahead and replace both IC's with the new updated and improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits in projection TV's then have a qualified tech handle it for you. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Posted on Aug 05, 2007
Yesterday I notice my Toshiba 42H83 rear projection HDTV has a convergence problem. The Touch Focus (auto convergence) adjust the Red & Green ok, but the Blu lines only adjust vertically, no horizontal movement. Tried it in manual and got the samw results, no lateral adjustment. I seem to be have a problem simular to the person who can't adjust the Red; looking for advice. I have a old O-scope, DVM, temperature controlled Soldering station, solder ****** (spring loaded), clip leads and other stuff. It has been awhile since I've repaired a TV and this set's technology is a different animal. Advice or documentation would be appreciated, if it is a long drawn out repair, maybe I can use it as an excuse to go get a Plasma, thinking of the wife here.
Posted on Aug 08, 2008
My Toshiba 42H83 (2004) has double (or triple) images. Is this something that can be fixed? Is the repair some sort of lamp? If so, is that an easy fix?
This tv have a problems known as a convergence problems,it dead.The tv convergence booard the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board, must be replaced to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 18, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
I am still working on it! Need a technician in Alacante Spain!
Jul 25, 2008 | Televison & Video
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83
Most projects in life are "easy",if you know how.Chassis will have to be pulled,convergence IC's replaced w/top quality parts to prevent recall.Some excellant soldering will be needed for prevent maintenance,for instance,the steel jumper wires feedig b+ to convergence IC's. RE-align in servicer mode==final step.
Aug 03, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 rear projection tv turns on but i have no picture or sound. happened suddenly. What can troubleshoot before seeking proffessional hel.
Check all micro-fuses in power supply.If two or three are bad,a convergence circuit O/H will be necessary.Pro help usually required-chassis pull,replace convergence IC's and careful hand- soldering needed to prevent call-back.
May 21, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
2,932 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
