My computer keeps shutting itself down without warning. I have live one care which prevents virus to pass through the system but the computer will stay on for a little while then shut off then stays on for shorter amount of time each time it is restarted.
    Scholar:
  • 77 Answers
It is possible this is caused by overheating. Check the power supply fan first, probably in the back of your computer tower. Do you feel any airflow? If so, the next thing to check would be the CPU fan/heat sink. Many motherboards have a temperature gauge software nowadays, or you can download one for free online to see how hot your CPU is running.
2 Possible solutions:
  1. Replace Power Supply if there is no air flow.
  2. Put in a new Processor Heatsink/Fan
Posted on Mar 12, 2009
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
The shutdown window keeps coming up and my computer shuts down
you have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
Mar 22, 2008 | Computers & Internet
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
Dec 12, 2012 | Acer Computers & Internet
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
My computer keeps shutting down automatically.
If it is shutting down by itself to a full power off then the first thing you should check is heat. Software could be an issue but the safe bet would be hardware. It sounds like it's overheating and shutting down to prevent damage. Check to see if the computer itself is warmer than usual. Listen carefully for sounds that are different or missing. It could be that a fan that failed that is causing an excess build up of heat. If you are comfortable doing so you should remove the cover and used a can of compressed air to blow dust off the boards and fans or if your careful you can use a vacuum, emphasis on careful.
Jul 16, 2011 | Acer Veriton 7200 PC Desktop
Dell xps 200 shuts down without warning. The powe...
Opitions:
1.) Your system may have an over heating problem
Make sure all your fans are running and not making excessive noise.
2.)You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 20, 2010 | Dell XPS 200 PC Desktop
Using windows xp the system shutsdown again and again during my work without giving any warning, however working with windows ME it works smoothly, why?
Windows XP "works" the CPU more than Windows ME.
So, the computer heats up, as the CPU works "harder",
and the computer overheats, and shuts itself down.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give the computer a "blow-job", to blow out all the accumulated dust, which is acting as an insulator, preventing the air-flow in the laptop from cooling itself down to "normal" temperatures.
Jan 02, 2010 | IBM ThinkPad T22 2647 Notebook
Harddrive keep shutting down
Does the computer keep randomly shutting itself down?
Think about these:
Is the computer located in a cupboard or enclosed area?
What is the ventilation like around the computer?
Have you checked for any dust inside the computer which could lead to over heating?
Try running a virus check on the system when it is stable, this may require booting into safe mode to do.
Oct 25, 2009 | Mirus Computers & Internet
Computer keeps shutting off without warning
If the PC doesnt show the shutting down dialogue, then hardware proble if it does then its a software problem. Try to replace the powersupply, abnormal voltage sometimes causes this problem, memory and motherboard errors can cause your PC hangs up or blue screen but will not shut off.
Oct 21, 2009 | Computers & Internet
My computer crashes or freezes a lot
It might be a virus.
Probably Lsass virus. This virus can get into your computer and really cause havoc with your network connections and also deny you access to certain internet sites.
You need a Lsass removal tool.
try to go here http://www.symantec.com/security_response/writeup.jsp?docid=2004-050114-1706-99
and download the tool, and follow the instructions.
good luck
Mar 31, 2009 | HP Pavilion a450n PC Desktop
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
