Whirlpool wwdc 6400
Indicator light not on and no power
2 Suggested Answers
  • 957 Answers
SOURCE: Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
Posted on May 13, 2014
Whirlpool wwdc 9940 , it's one in the 6th sense range. I believe my washing machine is stuck in demo mode and I cannot get it back to being usable. Help!! I have so much washing to do!
I don't believe there is a demo mode in a washing machine. You would either do a wash or not do a wash. The internet seems to know nothing about it either. Contact the dealer.
You do have the water switched on?
If you have used the machine normally before, you have a fault and need to call a repair man.
Aug 16, 2015 | Washing Machines
May 12, 2014 | Washing Machines
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
Whirlpool Cabrio F1 trouble code came up 3x recently. Called Whirlpool and they said washer was out of warranty. Once I told tehm about the post they said that it was a Whirlpool "Quality Issue" and would...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$@#
Jun 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My canon mp500 is displaying error code 6400. the alarm, and copy light are flashing. the usb cables are connected.the manual has no error code 6400 listed. please help me
That error indicates a problem with the sheet feed unit. Unfortunately this is not user fixable and will require you send the printer to Canon's Authorized Repair Center (for your local area, you will find it easiest to locate this via Canon's website).
May 26, 2008 | Office Equipment & Supplies
Insprion 6400/1505 w/1GB ram and 120GB SATA drive - won't power up.
mostlikely the vomit shorted out the mainboard in the laptop and it is no longer good. if you have warranty on it, I would sugest using it.....
Jan 28, 2008 | Dell Inspiron 6400 Notebook
Blinking red light
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
hope this helps. thanks.
Nov 13, 2007 | Dell Inspiron 6400 Notebook
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
