Question about Canon PIXMA MP160 All-In-One InkJet Printer
Flashing E3 error code for a paper jam
Printer has a E3 flashing error code for a paper jam. There is no jammed paper. Any ideas on how to clear this error code?
  • Anonymous Mar 13, 2009
  • marquiscater Mar 16, 2009
    Unfortunately, the rollers are not working either. I get absolutely no response when trying to clear the error.
  • 29 Answers
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Posted on Mar 15, 2009
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Persistent E3 error message (jam)despite there being no paper in the machine - will not clear
  1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
512 people viewed this question
old marine
old marine
