Question about Minicraft Models Full Electric Bed - Mattress, Rails
I have an ultramatice bed. Everything was working fine I turned on the massage and it wouldn't stop running. I unpluged the bed and now it won't do anything.
Power Down Box IC 2004A PWRDN Box Raven.17502013 has been crossed off with a red highlighter. 515926 Rev:B 108148-365 02/10 The Remote has Ser GA554775 Can it be reset, or what is the warrany on the bed.
2 Suggested Answers
SOURCE: Ultramatic bed problem - bed
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Posted on Aug 13, 2011
Which button turns on subtitles
If you have a digital Set-Top Box with digital cable service:
Using Navigator:
  1. Press the SETTINGS button on your remote.
  2. Scroll left or right to the Quick Settings category.
  3. Scroll down to select the Closed Captioning option and press SELECT.
  4. Scroll up or down to highlight On, On with Mute, or Off and press SELECT.
Using i-Guide:
  1. With your Set-Top Box currently on, push the POWER button on your Set-Top Box to turn it off.
  2. Immediately-within one second-push the MENU button on your remote. You should see a User Settingsmenu screen displayed.
  3. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable.
  4. Power on the Set-Top Box to return to watching TV.
Otherwise, if you have basic cable, please consult your television's user manual for instructions to turn on/off closed captioning.
Sep 17, 2016 | LG 32LG30 32 in. LCD HDTV
Insignia 39" LCD TV Model Number NS-39L240a13 Rev B TV has been turning itself on and off for days unless it is unplugged, just keeps going by itself infinitely. Does not register remote or buttons on the...
It sounds that the main system control memory IC to your TV is faulty. Replace it. It is a very small IC, having 8 solder termianals, can be located very near to main system control IC. Even though the size of it is very small, the function to it, when the TV is switched On is great. To this IC, where all the tuning data and other details of the set's condition is stored and retrieved when the set is switched OFF/ON.
Will look somewhat like these. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Nov 01, 2013 | Televison & Video
Blinking red light
You did not give a model number. If this is an older model Sony, I would be concerned with the audio IC with standby. This IC will be of the TDA-XXXX series. I doubt if you have a problem with power supply. If you can locate the IC mentioned, and read the TDA number, cross reference this in an NTE semi conductor manual. If it does tell you it is an audio IC with standby...replace this IC with the cross reference. Be sure to check any grounds that need resoldered in the same area as the IC mentioned. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sony Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Everything has red highlights. but adjusting with the remote does not change things to correct the problem?
Go into the menu with your remote a click on picture next scroll down to convergence and click on it. Follow the on screen instructions on how align or converge the diffrent color lines togeather. It will usually have a white cross on the the screen. This should solve your problems if not have a tech replace the 2 convergence chips in the back of you set
Aug 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I'm having convergence problems, the three colors will not align
this is a free question you have posted--I know these sets very well---red and blue move, but not far enough?
sd tech
Feb 15, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Minicraft Models Full Electric Bed - Mattress, Rails Logo
55 people viewed this question
Top Minicraft Models Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Minicraft Models Toy Expert? Answer questions, earn points and help others
