Question about Hitachi 60V710 60" Rear Projection HDTV
Lost the lamp cover is there a replacemnet
I lost the lamp cover for my hitachi 60v710 I was going to order this part part#ph33032 but hitachi says part no longer exists so does anyone know of a alternative lamp cover or maybe how to fabricate a lamp cover for it thanks
  • 40 Answers
Short your lamp door switch.. it may cause cooling issues but it will work. put on a table take the back off look in the area that the lamp door is there will be a switch.. trip it and tape it closed.. then turn it on if the lamp turns on you've got the right one..
Posted on Mar 13, 2009
Hitachi tv 60v710 turns off and on by its self every minute what it can be?
This problems it is related to the tv projection lamp.The tv projection lamp is inside the tv now.Been in the tv like a 1 1/2 or 2 years already?Tv is on and used it like 4 or 5 hours daily?Yes,than the tv projection lamp must be replaced should solved this problems.If the tv projection lamp already been replaced,than this problems are caused by the board that call the Ballast board.This Ballast board only job are to ignite the tv projection lamp only.
Jul 13, 2011 | Hitachi 60V710 60" Rear Projection HDTV
I changed the lamp almost 8 mths ago and now its not working again- same problem. please what to do
Get another Lamp Mats $99.00 1-800-628-1118
If you play this TV 24-7 you might need Lamp most lamps last between 5,000hrs of playing time,so when lamp has been played for 5,000hours then lamp goes bad.
Sep 30, 2010 | Hitachi 60V710 60" Rear Projection HDTV
My Hitachi 60v710 HDTV does not come on and when in off position lamp lite is red and when on lamp and led blinks red and power blinks blue what is wrong and can I fix it myself
Did you say the lamp blinks red? I assume you meant the lamp status indicator light. That probably means the lamp is burned out. Take the lamp assembly out and inspect the bulb. If you see a visibly burned capsule or broken wire inside, that's your problem (you don't need to remove the lamp from the assembly to inspect it, and don't touch the lamp itself - see next paragraph). When you replace it, be sure you clean all of the vents in both the front and back of the set. Dust-clogged vents will cause a bulb to burn out prematurely, or even explode. You may need to remove the back cover (unplug first!) to clean out a dust filter for the lamp cooling duct.
You can save money by buying a bare bulb and rewiring it into the lamp housing, but be absolutely careful never to touch the new bulb with bare fingers - the contaminants from your fingertips may cause the bulb to explode when it gets hot. Wear disposable vinyl gloves (the kind restaurant food handlers use) for this job. The gloves may be included with the new bulb.
Set a regular cleaning schedule for the vents. How often depends on how quickly the dust builds up. Just don't let them get completely covered with dust.
Sep 22, 2010 | Hitachi 60V710 60" Rear Projection HDTV
HITACHI ULTRAVISION DIGITAL TV.MODEL NO: SP60WS lamp light is red
The lamp should be replace to fix the no picture since the lamp light is red.
Download the user's guide and see pages # 69-72 for lamp replacement.
Jul 10, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Tv won't come on
I had the same problem took it to the repair shop and they replaced the bulb.Works fine now.
Bulb cost 199.00
Jan 25, 2009 | Hitachi 60V710 60" Rear Projection HDTV
When I turn the TV on the temp and lamp lights keep blinking
You probably need a new lamp and check the fan for the lamp if it is inop or to dirty it will not cool the lamp properly. Address these issues first and let's hope you have not blown the thermal fuse.
Lamp light
lamp is bad or lamp light.
Aug 03, 2008 | Televison & Video
IS IT THE LAMP?
The lamp indicator should indicate when your lamp needs replacing.
Feb 02, 2008 | Televison & Video
Hitachi 60V710 60" Rear Projection HDTV Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
