Question about Sony VAIO Digital Studio PCV-RX660 PC Desktop
Able to boot up to windows operating system but it freezes within 5 minutes
When I turn on my Sony VAIO PCV-RX660 PC Desktop it is able to boot up to the windows o/s. I log into windows and click around but after a little bit it just freezes and mouse stop working, key board stops working. Anyone know what causes this problem. Thank you in advance for all that reply. -ktang
  • Kevin Tang Aug 05, 2007
    Hi 24_seven thank you for replying. It started a while ago and it gets worse. Sometimes it would hang right at boot up and won't even get to the windows bootup screen.
  • notaxzi Sep 01, 2008
    BOOTS UP TO DESKTOP AND FREEZES,HAVE TRIED DIFFERENT APROACHES,NO DEAL
OK. I fixed my problem which sounded exactly like the problem you are having. What I did was: 1. Removed the top of the case 2. Removed my floppy drive (You will need the power cable for step 3) 3. Installed an exhaust fan at the top in the back by the power supply you will see an opening there. I used a 12v fan I connected the wires Black to Black and Red to YELLOW (This is because it was a 12v fan) 4. Removed the heatsink from the processor and cleaned off all crusty old thermal compund. 5. Applied Artic Silver 5, and put everything back together. 6. Did NOT put the top of the case back on. SO... thats that. It's been 2 days no crashes, I do notice a slow down once in a while. But I am wondering if that's just my computer trying to right itself from crashing for the last 3 weeks. Hope this helps.
Posted on Aug 15, 2007
Dood I have the SAME COMPUTER SAME PROBLEM!! I thought it was the summer heat. I cracked the case opened up the power box and used an air compressor to blow out the dust... there was A LOT of dust. The solution worked for about 30 min. Then started again. I have removed all unnessacary VIAO software years ago... I saw on another BBS they suggested doint this. "As some one in this forum suggested, I looked in the Admistrative tools in windows XP (Control panel\performance & maintenance\adminstrative tools\event viewer\system) and saw that each time my computer froze, my network card was involved. I took the card out and reinstalled it and now...ta da...no freezes." I dont know if this will work but The Service Control Manager is involved everytime mine crashes. Peas
Posted on Aug 11, 2007
  • 883 Answers
First, did this problem suddenly appear?...or was it slowly getting worse? It sounds like an interrupt problem with the video hardware. If this problem suddenly appeared, then boot Safe Mode and then run system restore to date just before problem occurred. If this came gradually, then solution is same as above except finding date will be more difficult and trial and error routine will be necessary.
Posted on Aug 05, 2007
  • Marty marty Aug 05, 2007
    also try this:
    open case and re-seat the video card and memory chips modules. Actually re-seat all connectors to mobo also including power.
Sony Vaio PCV-RX660 processor Upgrade
It should fit. Check the motherboard manual to see which CPUs will work in it.
Apr 30, 2012 | Sony VAIO Digital Studio PCV-RX660 PC...
How to dismantle sony vio desktop
This model simply requires the removal of the purple screw in the back side of the pc. Then, the side of the case would pull towards you.
Nov 07, 2010 | Sony VAIO Digital Studio PCV-RX660 PC...
SONY PCV-V1/G WOULD YOU BE ABLE TO GUIDE ME INTO THE RIGHT AREA FOR THE SOUND CARD DRIVER AND THE GIGA POCKET SET UP FILES THANKS MIKE
Use this link and click detect my model on the right.
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1
Mar 18, 2010 | Sony VAIO Digital Studio PCV-RX660 PC...
Sony PCV-A11 desktop won't boot up to windows. I see the Sony sign and pentium 4. Computer goes to a black screen with a blinking cursor. If I try to type something it won't accept. This all occured after...
Use your installation CD for Windows that came with your computer, and boot to the CD. (Usually, pressing the F12 key will offer your boot options such as "Boot to CD.")
Once booted on to the CD, it will offer you several options - Do NOT reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"chkdsk c: /r"
It will take a while for it to work all its magic, but that should fix your problem!
When it is finished, you can simply push the power button on your computer to turn it off.
When you next turn it on, it should be happier.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
I had a viris, and now when I start my system is says no operating system found. where do I get the disks to reload the operating system
According to the user guide you should have access to recovery utilities by hitting the F10 key during boot. From what I read that section of the bios also allows you to do data backup and recovery (may require the Sony Recovery Discs).
Just in case you need it - here is a link which will allow you to contact Sony for recovery discs for your machine.
Feb 21, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
Computer turns on, but does not boot to XP
Generally, fans are controlled by heat readings...something to check is the operating temperature that is shown in your BIOS when you boot up...(access your BIOS by tapping on the delete key, or F2 key while booting)..if it goes over 70C real quick then there is a CPU heat dissipation problem, which would cause the fan to run like this i think that it is more of an issue that your CPU died...has your machine taken any kind of hit or fall that might have loosened things?...or perhaps the heat sink compound between the heatsink and CPU failed.....
but it also could be a dead MB
Jun 06, 2008 | Sony VAIO Digital Studio PCV-RX660 PC...
Sony VAIO Digital Studio PCV-RX660 PC Desktop Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
