Question about Tools & Hardware - Others
Boston stand up stapler spring fell out - Tools & Hardware - Others
2 Suggested Answers
  • 406 Answers
SOURCE: How do I put the spring back in my Heavy Duty Stapler?
Find it on this video
Posted on Dec 09, 2014
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
Tr50 stapler loading spring fell out can I put it back in its nearly new maybe used 5 times
Reinstallation can be tricky. You have to be careful to avoid stretching the spring too much. That will weaken it.
Jun 10, 2014 | Stanley Office Equipment & Supplies
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Mar 03, 2014 | Stanley Black & Decker Bostitch 20SUITE...
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at www.surebonder.com on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
Mar 17, 2013 | Surebonder Pneumatic Stapler
Handle stuck in locked position
One of the screws - furthest away from where the staples exit - has a nut on it... Remove the nut, then - using pliers - back out the screw. When I did this, the spring returned, a bent staple fell out and once re-assembled I could use the stapler again (for a few turns). It seems like the stapler is VERY sensitive to bounce during the stapling, you must hold it very tight (and flat) to the material so that the staple doesn't jam inside the stapler. Lousy product.
Mar 16, 2013 | Powershot Tool Company PowerShot 5700KB...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Tools & Hardware - Others Logo
135 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
