Question about Canon imageRUNNER C3170U Color Copier
Canon IR1600 Loud Screeching Noise During Copying
The drum was replaced on February 4th. After the copier kept jamming the fuser was replaced on February 6th. Starting yesterday, March 11th, each time a copy is made there is a ear piercing screeching sound. Is there anything I can do other than call a Service Tech again?
Thanks!
  • Sergey Artuganov
    Sergey Artuganov May 11, 2010
    replace the drum agane.
    Before installing the drum wipe the rakel blade and nife by toner and roll.
    Rakel can damage drum
  • 92 Answers
Try to lube the gears of the main motor ,or the fixing unit on the bushings put some lube.
Posted on Jul 06, 2009
  • 59 Answers
There are some little metal earth strips that meet the paper exit shaft at the fromt of the machine. I've had a couple of these digging intot he metal exit roller shaft, they just needed bending away from the shaft anbit and oiling. It also helps if you move the exit roller shaft from front to back a bit.
Posted on Mar 23, 2009
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
Loud clicking noice during copying
take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Feb 14, 2009 | Sharp AL 1631 Copier
Brother MFC 8440 makes very loud noise when printing/copying
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Dec 20, 2008 | Brother MFC-8440 All-In-One Laser Printer
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Canon copier PC 420 making grinding noise during copying cycles
only two possibilities
1- fuser
2-gear stripped most likely with the scanning part
Oct 15, 2008 | Canon Office Equipment & Supplies
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Canon imageRUNNER C3170U Color Copier Logo
174 people viewed this question
old marine
old marine
