Question about Humidifiers
Instruction manual for carefree awninf model BN3N4
I am not getting any moisture. The fan just runs but no water is being evaporated?
How old is it? it may be time for a descale. Do you have any CLR or a janitorial or restaurant or dairy quality delimer/descaler?
Nov 28, 2013 | Hunter CareFree Plus 33222 Humidifier
I bought a hunter humidfier about 2 years ago and now i am using it for the first time. I took all the plastic off around it and opened up the top to make sure the filters and everything is in place. I...
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers. The fact that it is producing cold air seems to indicate it is working. However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Mar 07, 2011 | Hunter CareFree Plus 33222 Humidifier
Where can I find the userguide for my Hunter 33202 carefree hudifier plus?
I think this is what you are looking for. I hope that this helps. Don't for get to rate my help to you.. Thank you.
http://dl.owneriq.net/3/3d060e88-a7a9-48c5-b125-a63b40074d7c.pdf
Dec 27, 2010 | Hunter Care Free Humidifier Plus...
Water accumulation in tray under humidifier
what kind of humidifier? Are you getting condensation? Look at the windows in the room with the humidifier, if they are wet with condensation, then you have too much water in the air, also if it's cold enough the water can sometimes just fall instead of being absorbed 100% into the air...
Feb 22, 2010 | Hunter CareFree Plus 33222 Humidifier
I have a Hunter Carefree Humidifier Plus. When I
We were having the same problem. Here is how I fixed it but its hard to explain...
I took the main white part off and laid it side ways on a table looking inside there is a tube that goes from the top towards the main fan then connects to a plastic part that is shaped like a "p" In the middle part of the "p" you an see I tiny little gear. I manually turned the gear with a paper clip a few times and it worked. I had no idea what I was doing but I was determined!!!
Dec 07, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier # 34407 Nite Glo
the brown stuff is dust dirt unless you smoke then its that if you have washabule filter then wash it if not you must buy replacement filter thank you for useing fixya
Feb 17, 2009 | Hunter CareFree Plus 33222 Humidifier
Cleaning instructions
nvm :)
Features: Low Maintenance:
* Regulated Release ™ System - eliminates stagnant water while preventing mineral build-up on the wick or filter, which can impede performance in ordinary evaporative humidifiers.
* Dishwasher-Safe, Easy-Clean Base and Tank - with antimicrobial agents molded into plastic parts to inhibit the growth of microorganisms.
* PermaWick ™ - permanent wick never needs to be replaced, saving up to $45 per year in replacement filter costs.
* Top Down Water Dispersion - evenly disperses water from the top over the entire wick to prevent mineral build up that can impede performance.
May 22, 2008 | Hunter CareFree Plus 33222 Humidifier
Humidifiers Logo
53 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
