Question about Garden
Model 900745471 Size of line
How to spool the cutting wire
please see instructions on replacing the line on page 14 of the manual.
Make sure you buy the correct line size. Incorrect line size will cause lot of grief and frequent replacement.
http://www.poulanpro.com/ddoc/PPOO/PPOO2009_USen/PPOO2009_USen_PP025-545177327_952711878.pdf
Sep 02, 2014 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
Mar 06, 2012 | Mr. Heater Thermocouple
I need a replacement front wheel for a 16" Disney Princess bike. I cannot locate in local stores (ie, Walmart) or on line.
You need to search on-line for the size of wheel, not by the model of the bike. Look at the tire, it will be labeled with the wheel size.
Sep 02, 2011 | Huffy Disney Princess 16 in. Girls Bicycle
What size line does a ryobi CS30m gas trimmer use
The Ryobu CS30 model calls for only .080" line. Other models use larger line and electric models use smaller line.
Oct 03, 2010 | Ryobi Garden
What are the gas line requirments for the kenmore model 9796
Most of the time a 1/2" line will be plenty...
to really size gas lines properly there are a lot of variables...
distance, type of gas, BTU's and type of line must all be known and then charts consulted to properly size the line...
heatman101
Sep 20, 2010 | Dryers
What wire size do I need to run for a 1.5 ton AC unit in 220 volt?
It will be good to have a 3sqmm wire for the power line but if the line is going to be longer then increase the size to the next level.
This is because the AC on start up draws about 10 amps intially. the present models have bettter star ratings are consume lesser but a good conductor will not drop the line voltage.
Sep 20, 2010 | Heating & Cooling
How do I reload the trimmer line?
Depending in model usually they sell a cartidge reel with line allready. If your handy savy! you may doit yourself. Turn your weed eater around make sure & carefull with your gas spills out. The reel usually locks counter wise pull it carefully and it pos out, the get the right line size, depending in the size os reel you could go a few rounds with line make sure that one ends come out one hole & the other thru the other hole. It just snap in the reel and counter closed to lock.
Time for the GREEN man to come !!
Jun 29, 2010 | Craftsman 25cc Gas Line Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Fuel return line ;is it the same size or smaller than feed line
diameter of return is smaller and avaiable at the dealer or model car-airplane shops
Dec 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Car alarm in-line fuse
What type of alarm system is it? The size of the fuse varies slightly depending how extravagant the alarm is. You could try to low ball it and if it pops the fuse then get a slightly bigger one. You might start out at 15 amps. BUT, if you can tell me the make and model of the alarm then I might find out the correct size. I hope I can help.
-Andrew Hawkins
Mar 31, 2008 | Car Audio & Video
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
