Question about Nintendo Professor Layton & the Curious Village Games for DS
Answer to no 18 question
To change the dustpan
  • 37 Answers
Move match top right to bottom left of rubbish, then move the middle match along slightly to the left
the match that was top left becomes the handle .
Posted on Mar 13, 2009
What is the answer to -13=5(1+4m)-2m
What is the answer ...? is not a very precise question.
I see a linear equation in the unknown m, and I surmise that you want to find the value of m that makes the equality true.
-13 =5+20m -2m
-13-5 =18 m
-18=18 m.
m=-18/18=-1
Answer? is m=-1
Sep 22, 2014 | Office Equipment & Supplies
The baseboard installed automatic dustpan for my vacuum has broken. Not only do I miss the dustpan, but now I don't get good suction with my hose. Replacing the dustpan doesn't appear to be as simple as...
I am assuming this is a built-in system so it sounds like your tubing is blocked. The guys who do furnace cleaning have also cleaned out my tubing so if you have not had your furnace ducts cleaned in a few years you can get them to come in and do everything. Or if you know an electrician with a metal snake you could borrow that and stuff it down the tube to the vacuum - disconnect the vacuum power first.
Dec 18, 2017 | Broan-NuTone Vacuums
Chest freezer ice is filling up around the top of the inner lid
Turn it off, remove the stock, tap the sides with a block of wood and scrape to the bottom of the freezer with a dustpan and scoop it out. Refit the stock and switch back on. Takes 10 minutes. Check the lid seals properly once defrosted and check it's not accidentally in superfreeze mode.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Defrosting
Switch thermostat to "0". Alternatively switch off, open doors and scrape excess ice off inside walls. Do not stab at the ice. Knock remaining frost off with blunt hammer or block of wood and scoop out with dustpan before switching back on
May 19, 2012 | AEG Santo 3888 KG8 Bottom Freezer...
How to clean front cover M7Q08FZA
Spray with kitchen degreaser with filter gauzes out but cover closed. Allow to soak for 10 mins. Brush with nylon brush (dustpan brush) or old toothbrush to get into all the crevices then rinse with warm water from a garden low pressure sprayer and vacuum dry with a vacuum cleaner. Refit filters and run to check
May 17, 2012 | Maytag M7Q08F2A Thru-Wall/Window Air...
My nikon d90 18-105 won't shoot! cannot see live
if you are new to DSLR. set the menu setting default.
however there is lv button to see in live mode.
Dec 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Toner spread all around
Find Dustpan and Brush.
Start sweeping, sneeze occasionally.
Dispose.
Oct 12, 2009 | Ricoh Aficio MP 161 Black and White Copier
TROUBLE CODE 18 AND 41 HOW DO YOU FIX?
CODE 41
It means problems with ignition module. Remove the wiring harness connector from the module the resin that encapsulates the module circuit board was oozing out of the connector. try changing the ignition module or it may heve problems with the cam sensor . Check whether cam sensor interrupter (magnet) had broken off the cam gear.
CODE 18
CHECK THE CODE IS IT 18 OR 12 . PLEASE LET ME KNOW I WILL HELP YOU
PLEASE RATE THIS ANSWER
Jul 08, 2009 | Oldsmobile Delta 88 Cars & Trucks
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Nintendo Professor Layton & the Curious Village Games for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
