Question about Carrier Heating & Cooling
Missing fault code legend
I cant find a faut code legend for a carrier a.c model #FA4CMF036, could u please help
  • 3,361 Answers
Http://www.carrier.fi/dm/file.phtml?id=84
This should be what you are looking for.
If so, please rate this post.
Thank you.
Posted on Mar 12, 2009
1994 legend speedometer works once in a while
92 or 94?
is fuse 22 loose?
did the CEL lamp in dash glow at this FAILURE event
or S, D or D4 auto tranny lamps flash? BINGO,
did you look for ECU/PCM errors first.? that be first .
is the odometer dead? too, at same time?
on this car the VSS module (veh.speed sensor)
sends the speed data to 6 other modules. the speedometer is 1.
so of the other 5 are dead, its the VSS dead, if not its a bad speedometer.
on of those modules is the PCM, that runs the EFI engine.
so scan it, on this old car, you insert the diagnostic jumper
(service check conn.)
and read the flash codes from the CEL lamp in the dash.
this will show 17 error, VSS bad. if bad (its bad or bad conn)
easy huh?
log in to alldata.com and read the how to read OBD1 codes
it will be something like this. (photos missing)
When a fault is noted, the ECU (otherwise known as the ECM) stores an identifying code and illuminates the CHECK ENGINE light. The code will remain in memory until cleared; the dashboard warning lamp may not illuminate during the next ignition cycle if the fault is no longer present. Not all faults noted by the ECU will trigger the dashboard warning lamp although the fault code will be set in memory. For this reason, troubleshooting should be based on the presence of stored codes, not the illumination of the warning lamp while the car is operating.
All models are equipped with a service connector in side the cabin of the vehicle. If the service connector is jumped, the CHECK ENGINE lamp will display the stored codes in the same fashion.
The 2-pin service connector is located under the extreme right dashboard on Integra, Legend & 2.5TL; on Vigor models, it is found behind the right side of the center console well under the dashboard.
Codes 1-9 are indicated by a series of short flashes; two-digit codes use a number of long flashes for the first digit followed by the appropriate number of short flashes. For example, Code 43 would be indicated by 4 long flashes followed by 3 short flashes. Codes are separated by a longer pause between transaxles. The position of the codes during output can be helpful in diagnostic work. Multiple codes transmitted in isolated order indicate unique occurrences; a display of showing 1-1-1-pause-9-9-9 indicates two problems or problems occurring at different times. An alternating display, such as 1-9-1-9-1, indicates simultaneous occurrences of the faults.
When counting flashes to determine codes, a code not valid for the vehicle may be found. In this case, first recount the flashes to confirm an accurate count. If necessary, turn the ignition switch OFF, then recycle the system and begin the count again. If the Code is not valid for the vehicle, the ECU must be replaced.
and this warning
On vehicles with automatic transaxles, the S, D or D4 lamp may flash with the CHECK ENGINE lamp if certain codes are stored. For Legend this may occur with Codes 6, 7 or 17. On Vigor and Integra it may occur with codes 6, 7 or 13. In addition, the TCS lamp on NSX may flash with codes 3, 5, 6,13,15,16,17, 35 or 36. In all cases, proceed with the diagnosis based on the engine code shown. After repairs, recheck the lamp. If the additional warning lamp is still lit, proceed with diagnosis for that system.
Sep 19, 2013 | 1992 Acura Legend
Limit circuit fault and high heat only is active
Please clarify the problem, what is the brand and model of your air conditioner?
Oct 25, 2008 | Carrier Heating & Cooling
My carrier aircon model WCARG019EE is not cold & theres E4 code what does it mean?
According to the Owners Manual, E4 is a fault code that requires service by an authorized Carrier Serviceman. No other explanation for it was given.
Sorry I could be of more help.
Apr 29, 2011 | Carrier XCB123D Air Conditioner
My carrier unit is blinking 5 slow blinks and i can't find the fault codes to determine the problem. the model number to this unit is 58wav091-14
Dont know about yours, but the models we carry use fault code 5 to indicate low pressure/charge in the system.
Nov 30, 2010 | Carrier Heating & Cooling
I have a legend pride four wheel electric scooter. It does not run anymore. We checked the batteries and they are good and we charged them. We also went through all of the wiring and made sure the...
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
May 09, 2010 | Pride Mobility Products Pride Legend XL -...
I need help with my motorola w510, it needs a subsidy code
if you no longer are locked into a service agreement then the carrier who provides you service must furnish you with the subsidy code. I know this to be true because my daughter wanted a new cell phone and I bought here an expensive model. She gave me the old phone and since I have no obligation to the carrier, I called them and explained the situation and they gave me the subsidy code which unlocked the phone so I could use it on my carrier network which is different from hers.The phone she gave me is a motorola razr v3 and now it is mine and it is unlocked.
Mar 31, 2009 | Motorola Mobility W510 Mobile Phone
Need fault code help
try www.carrier.com and have your model number to look up the codes.
Jul 22, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
168 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
