Question about Acer NSK8458AN Keyboard
Function is not turning off
I used an external usb keyboard, and after disconecting it from the laptop, when I try to use laptop's keybord, it will display the function or numbers from the butons. ei: O,P will display 8,9
It will display the letters if I hold the Fn button down and type
  • 1 more comment
  • Anonymous Mar 22, 2009
    after i disconnected the usb keyboard from my laptop acer 6935 the keyboard stays on a different mode...all my function keys are active.
  • Tash Sep 28, 2013
    thanks a ton guys!
  • Tash Sep 28, 2013
    oops wrong section... lol
Try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard . Most laptops have a light that will turn on and off when you do this, indicating that the funtion keys are in use.
Posted on Nov 03, 2009
  • Tash Sep 28, 2013
    wow i'm so happy my keyboard works again... silly kids lol
  • Tash Sep 28, 2013
    thanks a ton!! :)
Can i replace the vga port on a compaq sr1115cl
If you have a DVI monitor, then you can use DVI to VGA adapter. eBay.com is a good source.
I guess you will use a USB external keyboard. If your laptop keyboard does not work anymore, then you can replace it with the new one. I think it is affordable (it cost less than $15).
Mar 05, 2014 | HP Compaq Business Notebook nx7400
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
How to function Fn
Step 1:
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key. The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function. The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop. Use the drop-down menus on the support page to choose the specific product line and then model of your laptop. Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys. Find the sequence of keys you need to press to unlock the function key on your laptop. Press and hold the function key on the keyboard and then press the other keys required to unlock it. Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys. Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
b>
Feb 15, 2013 | Gateway NV52L06u Laptop PC
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
I have an hp pavilion laptop and suddenly the keyboard stopped working, also i accidentally deleted my touchpad and the scroller ain't working.... please help me!!!
use aUSB mouse and bring back your touchpad it will for a while or take it to the vendor and get a new keybord or buy a external USB keybord portable one
Sep 06, 2010 | Computers & Internet
Unlock function key
you can fix the problem by following the steps
  1. tep 1 Check the manual that came with your laptop and locate the section on the function of each keyboard key. Open your web-browsing program and navigate to the support section of the website if you do not have the manual that originally came with your laptop (see Resources below). Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
  2. Step 2 Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop. Browse down to the section about the functions of the keyboard keys.
  3. Step 3 Find the sequence of keys you need to press to unlock the function key on your laptop and note them down. Press and hold the function key on the keyboard and then press the other keys required to unlock it.
  4. Step 4 Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key. Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
  5. Step 5 Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop. Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
thanks
May 20, 2010 | Toshiba Satellite 1410-S173 Notebook
Sony vaio laptop is turning on but the keybord+mouse not working
If your Keyboard and mouse are PS2 type, turn off your system, unplug them and try a USB type mouse and keyboard instead. If you are already using USB type mouse and keyboard, then try plugging them into different USB ports. Bootup in Safe Mode if possible. If you do not have keyboard functionality during the initial boot process, you may have sustained damage to the motherboard. The fact you mentioned a noise (speaker type?) and then lost component function, would indicate a possible hardware failure
Apr 14, 2010 | Computers & Internet
Keyboard, Touch mouse and all USB pads not working
first of all u have to re install windows( operating system)
before inserting the windows cd u have to plug an external keybord and mouse and start the system.
boot from cd and continue.
the laptop keybord and mouse could be unusable anymore.
May 24, 2008 | Acer Aspire 5100 Notebook
Keyboard detection problem
if the kb works on another system then the ribbion is ok, right?, the port on the motherboard is broken, which is almost certainly integrated(soldered to the board with no wires in between) which means to replace just the port you need to get a desoldering tool and cloth and a soldering iron(do not use a gun, they are not as acurate when working with this small of a space) and of course some solder, not to mention the replacement part or a more seriously broken laptop with the same part that you can take apart, seems like a lot of work to resurect a laptop, i would suggest a new board, new laptop or get a usb kb, maybe one of those rollup ones they sell on thinkgeek.com so you can retain some of the protablity, then again since the onboard kb is not functional it just sorta becomes deskspace for an external one. the fastest cheapest fix would be an external keyboard, next time i would recomend knowing what you are doing a little better before working on a valueable system or any that you cannot afford to loose, I see people break the ribbion cables and connectors all the time when working on laptops, its usualy because they dont know how to open the clips on the connectors, anyways try to be more careful next time
Jul 09, 2007 | Toshiba (225EXTR5)
Acer NSK8458AN Keyboard Logo
639 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
