Question about Garden
Woods rm 306 finish mower, can some one help with belt configuration there are like 8 pulleys, one long belt
5 Suggested Answers
  • 376 Answers
SOURCE: I need a belt diagram for a Landpride 6' finish mower.
Check out their website and look under manuals. http://www.landpride.com/main_products/main_gm.html
If you don't find it there, I'm sure customer service could hook you up...
Posted on May 28, 2009
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
  • 401 Answers
SOURCE: I'm trying to locate a users manual for a Woods Zero Turn mower model 2560 yr 2000
Go to their website, the owners manual is there
http://www.woodsequipment.com/files/Products/Manuals/MAN0875.pdf
Posted on Sep 24, 2014
sulgrave55
  • 1051 Answers
SOURCE: How to replace belt on woods rm660 finish mower
not sure about the 660 for sure but normally the woods mowers have a tensioning wheel that keep the belt tight when it is running and if you depress the wheel it should allow you to remove the old belt and put on the new one. Take a look and see if one of you pulleys has a spring attached to it and if so that is the tensioning wheel.
Posted on May 09, 2015
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
May 08, 2015 | Woods Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
WOODS ROTARY MOWER RM 306-3 OPERATOR'S MANUAL 386
www.woodsequipment.com/manuals.aspx
Sep 14, 2014 | Garden
Sears mid engine 30 inch breaks drive belts
for a belt to wear on the inside means that the pulleys are badly worn or you have the wrong section belt in use.V belts never work on the bottom of the pulleys.For a belt to operate properly the top of the belt should be just above the edge of the pulleys. For variable speed pulleys the belt should never make contact with the bottom of either pulley. Measure across the top of the flanges of the pulley and that will be the first number of the belt you require ie 14v1406 will be a 14mm wide belt and 1406 mm in circumference. or 3/8 41 will be 3/8 across the top and 41" long
Jun 14, 2013 | Craftsman Garden
Our woods 1250 zero turn mower will not turn left sitting on the mowerit won't go left it just goes in a circle is the hydrostat unit out howmuch to fix and the left side does not have a fan
check your tire shear pin frist and check your idle pulley too, and belts. also check to see if your unit has cables to the hydro. if so one might have broken. if all looks good, its more likely an axle problem, call your local service center
Oct 15, 2009 | Woods Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
