Question about Toshiba 42HL196 42 in. LCD HDTV
Tv does not turn on. Makes ticking clock sound ?
  • Anonymous Apr 06, 2009
    blinking red light but never turn blue
    Problem Solver:
  • 13 Answers
The blinking light means the controller QA01 in the AV_TERM system board is booting and driving the TIMER/REC RED LED light accordingly. This failure mode is true for many conditions, not exclusively for the main PS board PE0071. It could be caused by many things, LOW B, SEINE, AV_TERM, LCD, PROTECT, etc.
Specifically for PE0071+12VDC circuit failure, which is the most common , listen for the LINE relays SR80, SR81 coming online.(ticking clock sound) If several (3) or more clicks are present when applying power to the TV set then suspect the +12, 20, +32 VDC inverter is faulty.
As a quick check, you can disconnect P807B. If the relays cycle every 1-2 seconds then is most definitely the +12VDC inverter. Check for voltage level at optocoupler Q881 pin 4 and this should not be cycling. This point is the VCC for the oscillator. Repair or replace board 75002913 as necessary.
TROUBLESHOOTING: (this is my own, not the OEM !, try at your own risk!)
  1. Check for LINE1 input voltage level at inverter on sheet [4].
  2. Check for LINE2 input voltage level at inverter on sheet [3].
  3. Check for STBY +5VDC & +25 VDC ( observe correct GND REF) page [4]of PE0071 POWER
  4. Check for +22 VDC out of regulator on page [3] out of Q822 Emitter
  5. Check P809B connector for :
  • P809B (12) POWER = 3.00 VDC (+/-0.2)
  • P809B (11) POWER_SIG = 0.00 VDC (HIGH to Power on TV)
  • P809B (10) PROTECT = 0.00 VDC
  • P809B (9) ACDETECT = 3.00 VDC (+/-0.2)
  1. Check for PFC_OUT = 368-371 VDC
  2. Check for +12, +20 & +32 VDC inverter page [5] of schematic manual.
For +12 VDC Inverter, suspect components:
Q880 STR-W6765 PSR (works really hot!!)
C888-C890
D884A and related switching circuit components.
Good luck,
mrwindex
Posted on Nov 08, 2009
  • GregUSA Nov 01, 2010
    Can you confirm which board is which? I have this same TV with the same problem and thought I just replaced the power board. I replaced the one that the wall plug attaches to. I don't have access to a schematic but two black relays on the board above this one are clicking on power up and the red light stil blinks three times.
    Any suggestions would be very much appreciated.
I ama retired TV repair man and what you are hearing is the safety circuit trying to star and then shut down. Some where in the set there is a shorted component and the safety circuit is proyecting the set. There is no repair you can do the set must go in for service.
Posted on Mar 12, 2009
Why does my volume go out on my LG tv..makes a loud ticking sound then volume goes out
Audio amplifier failing or poor connection on board when hot. replace main board.
Oct 15, 2014 | LG 42LG50 42 in. LCD HDTV
My samsung WS32Z306V WONT TURN ON AND JUST HAS A TICKING COMING FROM THE BACK PLEASE HELP
Hi, Sorry this is not a fix but i wanted to say that i have the same problem on my tv which is the same model as yours.
At start tv would show faint parallel diagonal lines until some day it stopped working. Everytime i try to turn it on it doesnt! and makes a ticking sound from the back of the tv. Did you fix yours btw?
Feb 22, 2010 | Samsung WS32Z308P 32" TV
When I turn on my TV (KF50WE610), it makes ticking
Hi,it sounds like a problem with your ballast.The ballast is the board that powers the lamp .When it starting to fail it will make clicking sounds.The part is around $40-$60 depending where you look for it.I believe there's instructions on youtube.Have a bless one!
Feb 09, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Compact refrigerator stopped cooling. If you turn the thermostat on the light flickers and makes a clicking sound. If you turn the refrigerator off the light stays on. In the back you can hear it ticking...
The clicking sounds like the compressor is trying to start. If the condenser fan running? If it is then you need to check the relay of the compressor. It could be a bad compressor.
Jun 14, 2009 | Refrigerators
My tv want come on;
If your set is rear projection set you have a bad flyback transfromer or high voltage trippler is bad .
Jan 26, 2008 | RCA P52928 52" Rear Projection Television
No picture, then no picture and no sound
if your could hear a slight ticking (tick-tick tick) or whining then some electronic component might have been damaged (shorted). if you have no experience repairing electronic equipments then i suggest you to send your TV to a service station!
Nov 14, 2007 | Toshiba 27AF42 27" TV
Ticking Sound When TV is off.
it's normal (if you see the instruction manual) but is hell anoying men, i need to dissconect the tv from power at nights because the ticking sound doesn't let me sleep! i hate it :(
Dec 18, 2006 | Sanyo DS27930 27" TV
Toshiba 42HL196 42 in. LCD HDTV Logo
3,238 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
