Question about Husqvarna Yard Tractor
Weak pull up hill
When going up hill this lawn tractor slows down and does not have the same pull as it use to. The drive belt has been replaced and the motor seems to be running OK or as expected. My guess is that the transmission is on it's way out. The tractor was purchased in 2009. So in 4 to 5 years the transmission could go? How to you know for sure that its a transmission issue?
  • 3 Answers
SOURCE: i have a 2005 husqvarna lawn tractor. 24 hp, 48 in
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
Posted on May 10, 2009
  • 4 Answers
SOURCE: Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Posted on Sep 17, 2009
  • 112 Answers
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Posted on Jul 21, 2010
  • 10865 Answers
SOURCE: Just bought a used Husqvarna ltg 2654 mower. Could
Hello aka.... begin by checking the transmission fluid level. Fill it to just slightly above full when the tractor is sitting on the level. This will maximize your power. IF this alone does not solve your problem I recommend changing the fuel filter and the air filter and also adding a fuel additive called seafoam which will clean the internal engine parts. Joe
Posted on May 02, 2011
  • 407 Answers
SOURCE: My husqvarna tractor is slowing/stopping
check for dirty air filter,dirty gas filter,loose drive belt,oil in rear end.GL
Posted on May 10, 2011
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
Aug 26, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Does not want to pull up hill
there is a plug of the axle can't always get to it also check the drive belt
Aug 11, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
M 917258571 does it need tran fluid it won't pull up hill good
Most likely the drive belt is slipping. It either needs an adjustment { if this model has an adj.} or the belt needs replacing.
Apr 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hydrostatic drive seems to be weak. belt to motor isn't broke. seems to slip more and more as you go. up hill pulling of lawn rake nearly impossible.
Try using the heel of your shoe and pulling back on the brake/clutch pedal and see if it helps. Cronic problem with these mowers-Belt slipping when linkage get a little wear-with no solution???
Apr 24, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
May 31, 2009 | Garden
Husqvarna Yard Tractor Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
