Question about Radio Communications
MY CB powers up, but no sound from my speaker
The speaker works, I ran a new antenna, I purchased a CB, same model used from ebay, same problem Help
Benimur
  • 6966 Answers
SOURCE: New radio
Assuming no hardware faults, start with the basics, on powering on the radio:
1. RG Gain max clockwise;
2. Ch 9/NOR to Normal;
3. Delta Tune to mid position;
4. CB/PA to CB;
5. Squelch to minimum counter clockwise;
6. Channel selector to desired channel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 30, 2008
Communicomm
  • 90 Answers
SOURCE: cb antenna
Wilson makes the best antennas & they offer 4 with magnetic mounts:
Little Wil, 3' long, least expensive
Wilson 500, 5' long, mid-priced
Wilson 1000, 68" long, more expensive
Wilson 5000, 68" long, overkill
I personally use the 500 & it's great. Keep in mind that the antenna is the most important part of a CB system & you get what you pay for.
Posted on Sep 06, 2008
  • 13 Answers
SOURCE: Cobra 75 WX ST powers on but does not work
MAKE SURE THE ANTENNA IS NOT CONNECTED, THEN TRY AND SEE IF RADIO POWERS UP, IF IT DOES NOT THEN YOU DO NOT HAVE PROPER GROUND
ALSO ARE YOU USING THE COBRA STOCK MIC ?
ALSO MAKE SURE THE RADIO IS ON CB MODE NOT WEATHER MODE
Posted on Apr 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
  • 41 Answers
SOURCE: I dont get any range on my cb. I used to have over
It is possible that the RF final in your radio is blown. The only way to verify this is to purchase an SWR Meter. This will tell how much power you are putting out and how mauch power is being reflected back into the radio. The other option is to go to a CB Shop and let them check your radio and antenna system out.
Posted on Jul 13, 2011
I have a uniden bearcat 880 cb. I works great sitting still but moving down the road it picks up nothing. Can somebody help me out I can't figure it out
what antenna type are you using. What is the standing wave ratio of the antenna.
http://www.ebay.com.au/gds/A-GUIDE-TO-INSTALL-CB-RADIO-ANTENNAS-WHAT-IS-SWR-/10000000000925345/g.html
Jan 04, 2015 | Radio Communications
My cb radio is on but cant hear nothing sound is turn up but nothing come out
You didn't include the make / model CB you have, so I can only offer general suggestions. If these do not work, please provided the missing info.
Start out by locating and setting the the Volume to a position between 1/4 and 1/2 way clockwise, the Squelch to fully counter-clockwise and the "RF Gain" to fully clockwise to "MAX".
Check the position of the "PA / CB" switch and set to CB. When set to PA, both receive and transmit audio is sent directly to an outdoor speaker (instead of through the transmitter and antenna for reception by other radios). The PA speaker is usually connected to a jack at the rear of the radio. When the PA / CB switch is selected, the internal speaker is silenced even if there is no PA speaker connected.
At this point, you should hear static or voices (with an antenna connected). Do not attempt to transmit without a properly tuned antenna connected. If no sound is heard, there's something else wrong.
May 22, 2012 | Uniden Pc 78xl Cb Radio Mobile
I have a Galaxy DX33 HML. I want get as much output power and receive as possible with being pushed to the limits. What mods would you do without over doing it?
Your radio will only do 11 watts out of the box. The antenna has alot to do with your range along with a few other factors. I normally suggest using a Wilson trucker 1000 antenna on tractor rigs. and a larson Antenna on regular cars and trucks. There is one other thing you can do to increase your power. Purchase an RFX75 on Ebay and have a local cb shop install it for you. this will increase your power to about 80 - 100 watts PEP.
Jul 11, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
I purchased a Midland 1001z in the fall of '09 and installed it on my boat. I is mated to the existing Shakespear 8' CB antenna. The CB worked great last summer while boating with my brother and...
Vibrations on the small cb's make the internal circuit boards come loose and its intermitted or will not RX or TX.. Check the antenna with another cb. using an SWR METER.. or have someone check it.. SWR should be free if you take it to them.. to check.. Make sure the antenna, mounts, and coax are ok.. if soo then its in the cb itself .. Email us if you need more help or need the radio looked at, the post office has flat rate boxes cheap nowadays. were in Temple, TX at the CB SHop.
May 30, 2011 | Midland 1001Z 40-Channels Base CB Radio
Purchased CB radio kit from Maplin with TTI brand CB and mag mount aerial in kit. Installed new CB's using a cigarette lighter adapter which plugs into lighter. CB comes on fine and this appears to be...
Sounds like you have a bad antenna.Altough it might be new doesn't mean anything I have customer come thur my shop with new antennas that they bought mostly from truck stops that have the same problem most of the time they have no ground,although its a magnet mount it can still read bad,take it to an honest shop and let them help you.
May 17, 2011 | Radio Communications
Hello there:
Mar 26, 2009 | Uniden Radio Communications
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
School project
When you talk into the microphone your voice which is sound pressure is converted to electrical voltages then it is increased in power to about half of the power of what the CB will sen out to the antenna. To make the CB radio transmit, there is a circuit that creates the proper frequency or channel. It is then increased to about twice the power of the voice circuit. They are combined together just before it goes into the antenna.It leaves the radio and goes into the antenna where it leaves the antenna as an electromagnetic wave. Electricity in the air with a certain value of frequency and strength. When the CB receives, The antenna picks up a signal, an electromagnetic wave, as it passes by. The electromagnetic wave, which is a small voltage, with a certain frequency and strength, enters the radio where it is processed . It is then increased in power . It is now connected to a speaker. The speaker is also a converter. It converts electrical voltage back to sound pressure so we can hear it. As the electrical voltages make the cone of the speaker move in and out. There is a lot more detail than this but this should help. Many things happen inside the radio that cant be explained in a few paragraphs.
May 14, 2008 | Cobra 29 LTD CB Radio
Cobra 18 wx st cb problem
Sounds to me like your finals in the rig have blown stopping you using the CB mode, Either that or you have a loose connection on the power output inside the radio.
Mar 15, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Cb feedback though external am/fm speakers
Hi Big OX,
Terrible problem.  I know what your going though.  Route your AM/FM Antenna wire, and Speaker wires separate from the  CD Antenna cable and power supply wires. If you can,  twist the speaker wires.  If the Speaker wires are run along side the CB Antenna wire for a short distance, you will pickup feedback. If you much have the Antenna wire get near the speaker wires, have the antenna wire cross the speaker wire at a 90 degree angle. Try not to run the antenna wire in paralell with the speaker wires.   Good luck
Oct 27, 2007 | Car Audio & Video
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
