Question about Starmark Flavor Wave Treats
Flavor wave fan noise - Starmark Flavor Wave Treats
The fan stopped working on flavor wave oven
The fan can be tested if the unit is taken apart by a qualified person--removed they directly apply the correct voltage to see if it runs or not--what is found will determine if fan or something else is bad.
Jun 15, 2012 | Microwave Ovens
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Fan has a internal rubbing noise when in motion. Is there a way to use some electrical/ teflon oil to ease it's pain.
MOTION NOISE OCCUR IN THREE WAYS
1. The bearing of the fan is not good, apply greese or lubricant oil on bearing as on manual
2. The fan blade is not fixed properly, tight all screws, some times its blade is bent correct it.
3. The fan is operating on square wave frequency when it is working on an invertor, use a sine wave frequency
Aug 21, 2009 | Dryers
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Buzzing noise from speakers
The buzzing noise is being heard probably because there is another electronic device around that's using radio waves to function. (Such as a cell phone, a cordless phone adapter or a wireless router. Even microwaves and ceiling fans can give off these sounds.)
My advice would be to try and move around or turn off some appliances in your room that may give off radio waves.
Sep 18, 2008 | Logitech Z-2300 Computer Speakers
Starmark Flavor Wave Treats Logo
75 people viewed this question
Top Starmark Cats Experts
Tom Chichester
RANDY POWERS
Level 1 Expert
isojim
Level 1 Expert
Are you a Starmark Cat Expert? Answer questions, earn points and help others
