Question about Garden
How to replace flywheel on my stihl bge 71 - Garden
3 Suggested Answers
  • 7 Answers
SOURCE: i need amanuel for a stihl she 71 blower
only manual available from stihl on any of there equipment is operators and safety manual,they do not have service manual available to the general public,if you go to stihl.com or stihl usa you can down load owners and safety manuls
Posted on Oct 02, 2009
dontbother10
  • 2220 Answers
SOURCE: removing flywheel and clutch assembly ms 250 stihl
You need a piston stop, watch part of this to explain use:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Make one with starter cord or rope:
I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. HTH
Lou
Posted on Nov 19, 2009
Testimonial: "Thanks for your help, I got the clutch assembly off with the rope as a cylinder stop. But the flywheel is going to require a puller i think."
How to remove clutch from Stihl fs81 brushcutter?
go google and type in --workshop manual for Stihl brush cutter model fs 81 -- and download the pdf version from the stihl site
Feb 08, 2016 | Stihl Garden
How to replace a flywheel on a Stihl bg55 leaf blower,
it may. just make sure it's centered.
Feb 18, 2015 | Stihl Garden
How to change flywheel on bg86c stihl blower
  1. Remove fan housing
  2. Remove spark plug and install piston stop.
  3. Remove flywheel nut.
  4. If flywheel is struck on use a puller. Stihl uses a knocker type puller that screw on the crankshaft and tapped by a hammer. Be carefully not the damage the crankshaft stud or the bearing.
  5. To install reverse the above skipping item 4. Just make the flywheel engages the slot in the crankshalf. The flywheel nut is torque to 17 nM or 150 in lbs. Don't over torque the nut or damage will occur to the flywheel.
Dec 16, 2014 | Stihl Garden
Why won't my Stihl blower not run?
check for spark first thing if spark sqiurt some starter fluid in the carb start it if it trys to start rebuild your carb dirty or water in gas dump tank put in fresh mixture not same one again
Aug 26, 2014 | Stihl Owners Instruction Manual Leaf...
Stihl saw igtion timing
The ignition timing on all Stihl saws is, as far as I am aware, set by the key on the flywheel and not changeable. If there is a problem check the flywheel still has the key moulded in place in the tapered hole that goes onto the crankshaft . If it is missing you can get a replacement after market flywheel or cut yourself a 'woodruff key' of the same thickness as the groove on the crank shaft and cut a corresponding groove into the flywheel EXACTLY where moulded key used to be. Refit the flywheel with the woodruff key in place - possibly sticking it into the flywheel with 'Locktight'. Make sure the flywheel is tightened fully onto the taper of the crankshaft when refitting otherwise the grove in the crankshaft will get wrecked!
Jan 07, 2014 | Stihl Garden
Can't get a spark on Stihl 020 chainsaw. Tried another coil and switch module but still no spark
It is possible your flywheel has lost it's magnet strength, if you noticed it turn a blue. Can take off flywheel and replace with a good one. Or you can play with the gap on the magneto/coil, and insert a piece of paper between the coil and the flywheel magnets, to set for air gap.
Sep 09, 2013 | Stihl Handle Chainsaw 020 Avp
Replaceing keyway
If the timing is out and the keyway on the flywheel is damaged then you must replace the flywheel. There are ways to 'bodge' the flywheel but its not worth potentially damaging the machine.
Flywheel part number is: 4203 400 1200
Feb 26, 2013 | Stihl Br420c Magnum Leaf Blowers
Does a stihl 064 flywheel fit an old stihl red eye 066
What's a red eye? If the first four numbers from the old flywheel match up with the ones on the replacement, they should swap. I'd suggest just getting the correct one instead of trying to jerry-rig a chainsaw. eBay is a great resource for used parts and they're usually fairly cheap.
Oct 23, 2012 | Stihl Garden
Stihl ts400 no spark
I have never seen a flywheel de magnitise, it will be an ignition unit problem
Jan 11, 2012 | Stihl Saws
I need amanuel for a stihl she 71 blower
Sep 29, 2009 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
