Question about Dell Axim X5 Pocket PC
Backup Battery draining fast
The backup battery will drain in about 2 hours. Even after replacing with new battery, results are the same. Why is it draining before the main battery? The only way I can use this unit is to leave it hooked up to the charger at all times which does not make it mobile. The backup battery should last a long time.
  • Susan Hancock Aug 05, 2007
    I am using version 4.20.1081 (build 13100)
  • Susan Hancock Aug 06, 2007
    How do I know if I am overclocked?
  • 31 Answers
What version of windows moblie are you using? Is it overclocked?
Posted on Aug 05, 2007
  • Richard Martin
    Richard Martin Aug 07, 2007
    CPU frequency options are in power. Just trying to be helpful. You must state all the information to come to a solution.
SOURCE:
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Hp proliant dl 380 server
    How big is your UPS backup. Small home / office only last a few hours before the battery drains. Their role is to allow time to save work and shut properly. Large enterprise UPS's last longer, but are dependent on battery bank size and configuration.
    Jul 16, 2012 | HP ProLiant Computers & Internet
    My Nokia 5800 battery reduce with in a day?how can i solve the problem of draining battery?
    this is a multimedia phone having much features, if you are using this phone for listening songs/video then backup of one day is ok but if the condition is in normal usage (normal phone calls and some songs)it mean you have to replace your battery for long backup but before that try to reset your phone with factory settings. (battery consumption is also based of network strength,bad network **** the battery in a fastest way)
    if every thing is correct then go to change battery connector.
    vote me if found helpfull.
    Aug 04, 2011 | Nokia 5800 XpressMusic Smartphone
    When i charge the phone the battery dies quckily
    Please change the catergory, this is not a problem with a laptop, and please provide more information on the phone next time. Thanks!
    May 19, 2011 | Computers & Internet
    The last 3 days, my battery lasts only a few hours. It used to last at least 15 hours
    Battery and Usage under Settings will tell you exactly what is draining your battery. You should power your phone off for a few minutes every 2 or 3 days.
    Also try letting the battery die completely, and charging up to full UNINTERUPTED. This will help the phone reset it's battery meter, which may be the problem.
    Your next step would be to backup the phone, apps, and SD Card files, and perform a factory restore. Then reinstall your apps and replace your data.
    If that fails, you may simply need to purchase a new battery.
    Apr 13, 2011 | HTC Hero Smartphone
    Im using brand new NEO basic B3353 notebook, how many hours before the battery drain? because mine is only takes 30 minutes
    HI FRIEND A BATTERY WORKS ABOUT 1HOUR AND 30 MINUTES TO 2 HOURS MAXIMUM WHEN IS FULLY CHARGED. SO I SUPPOSE YOUR MIGHT NEED REPLACEMENT BECAUSE IT IS POSSIBLE TO START HAVING WORKING PROBLEM.SO I SUGGEST TO REPLACE IT WITH A NEW ONE AND IT WILL WORK PERFECT
    Apr 09, 2011 | Computers & Internet
    1000 VA 600W-S/N:20436760610. Unit failed after
    I have gone through a few UPS, Im lucky to get 3 to 4 minutes if my power is cut.
    I think most people plug too much into the UPS sockets.
    The Battery backup protected sockets cant take the drain from everything over a prolonged period of time.
    The nature of rechargable batteries means that when plugged permanently into a power supply they get damaged (li-on batterys especially).
    Im afraid i cant help with this UPS, looks like you need a new 1.
    I now only have my PC/Monitor/modem and router plugged into the UPS protected sockets.
    Speakers / printer and other stuff are plugged into the unprotected sockets.
    Jul 20, 2010 | Ultra Products 1000 VA 600 WATTS Backup...
    Replaced ipaq 4150 internal backup battery but
    read the manual yet, or lost it> or?
    most of these have 2 batteries
    one that pops out one more that solders down.
    guess which one retrains data.
    finding parts for relics like this is not fun
    what good is this thing besides, wall art?
    why ask here at all, we are not HP , nor are there HP books here.
    so ask here.
    there are folks there that might remember so long ago
    or even have old books laying about after all they are HP.
    https://h30434.www3.hp.com/
    Dec 10, 2017 | HP iPAQ H4150 Pocket PC
    Battery gets discharged
    Possible Problems:
    1. Maybe there's a virus.
    2. Often restart can drain the battery.
    Possible Solution:
    Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
    OR...
    Format it by typing *#7370.
    Aug 03, 2008 | Nokia 3230 Cellular Phone
    Dell Axim X5 Pocket PC Logo
    140 people viewed this question
    Ekse
    Clive
    Clive
