Question about Baby Care
Graco swing I have a graco swing, the swing doesn't work when the adapter is plugged in. How can I fix it
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I'm not sure if you tried a different outlet plug yet, but I would try to eliminate whether if its the power source (outlet) or the swing itself. Also, if the outlet has a reset/test buttons on it, then it might have tripped itself.
Posted on Apr 23, 2013
  • 13 Answers
SOURCE: My 6 speed Graco swing will not work. The motor
It sounds like the problem is in the motor. Because of the heavy load on the motor during normal swing operation the brushes that are attached to the communicator are wearied out. This causes a loose contact between the brushes and communicator and the motor is loosing his power. Ideally, I would replace the motor. The only a problem is that the available replacement motors have a short shafts, when the motor used in Graco swing has a very long shaft. So, there are two solutions: buy a new motor sage from Graco for $28; OR buy a new motor ($5-$7), then carefully remove a nylon end cap from the old motor and replace it with the nylon cap from a new motor (WARNING: you have to be careful when doing this, because if it will be done inappropriately the brushes can be easily damaged)
Posted on Feb 11, 2011
jyackle5
  • 8197 Answers
SOURCE: i can not find the
You can get the manual on the link below.
http://download.gracobaby.com/ProductInstructionManuals/PD118655A.pdf
Posted on Apr 29, 2011
SOURCE: i have just purchaced a
There is a plastic casing around where the leg snaps in. Lift this section with a screwdriver being careful not to break it. With it lifted, push down on the end of the leg that is incorrectly inserted and push down. I had the sane exact issue and this is how I figured it out. Good luck!
Posted on Jun 09, 2011
  • 6771 Answers
SOURCE: Hello. The sound on my Graco baby monitor is no longer working. Vibrating still works but if the baby is crying I can't here it through the monitor. Any solutions? It is still under warranty,
Return item to the place of purchase, this clearly is a manufacture issue.
Posted on Apr 02, 2012
SOURCE: how to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Posted on May 01, 2012
Does the Graco Duet Soothe have a fuse? Im hoping that is why this stopped working.
It has a plug. The swing also uses batteries if it's not plugged into the wall. You can also order replacement parts from Graco's Website.
Apr 10, 2017 | Graco Baby Gear
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
How to disassemble graco swing
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
There a bar that came off the swing that I have. Just using for the first time it was given to me by some one so it does not have instructions. So can u pleaseeeeeeee help me and tell me where the bar is...
Most of the time if you go to Graco's website they have manuals for these type of items. I had to do it for my new Fisherprice swing. If you can not find it there call them and they will send you one. I had to do that before too.
Jul 08, 2011 | Graco Winnie the Pooh Swyngomatic Infant...
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Nov 15, 2009 | Graco Baby Gear
Baby Care Logo
674 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
