How do i hardwire Compaq cq62 power cord. Dog
How do i hardwire Compaq cq62 power cord. Dog chewed the end of mine off where the jack is
  • 32,281 Answers
Most likely there are two wires a + and - power wires.
If you strip the broken ends of the wires on the plug and the end of the broken cable then you can solder the broken ends of the wire together. make sure the colors of the wires match and the wires are insulated so they do not short against each other.
Posted on Apr 23, 2013
5 Suggested Answers
  • 383 Answers
SOURCE: Power Trouble
How to replace the CMOS battery. Like any battery the computer CMOS battery can fail or lose its charge.
No power or computer does not turn on. No power from the computer can be caused by any of the below possibilities. ... into the laptop you should see a power light or battery charge light.
How to replace the CMOS battery. Cause:. Like any battery the computer CMOS battery can fail or lose its charge. ... Most likely causes are bad power supply or bad motherboard.
Good Luck, Please dont for get to Vote.Thank you.
Posted on Dec 19, 2007
toddg
  • 171 Answers
SOURCE: neeed powercord for 557s laptop
The Balance CN6555 PC Notebook is actually an ECS (Elitegroup Computer Systems) 557. Their website can be found at
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=3&TypeID=13&DetailID=479&DetailName=Feature&MenuID=58&LanID=9
The power cord may be found at most electronics stores. These are not all that hard to find.
Posted on Sep 24, 2008
JackHeath
  • 1049 Answers
SOURCE: won't Boot, power cord bad or perhaps female
It is most likely the female jack your adapter plugs into. Many laptops can have this port break if the laptop is put into a bag, etc with the power chord attached. Since it is attached to the main board itself, this is very hard to fix. Some vendors however will cover it under the manufacturer's warranty.
Posted on Oct 01, 2009
  • 1481 Answers
SOURCE: My dog chewed my power cord. Dh
ask the dog.....!!!
ok sorry jokes apart...
was the battery working before ur dog helped u out...
remove the power cord and check how long ur battery can hold on till it dies down...when ur notbook is ON
if it holds for more than 10 mins then the battery will charge if the power cord gives it enough power to charge, else u may have a power adaptor that gives enough for notebook to work but not enough for the battery to charge at the same time....
u may have to change both the adaptor and battery....or else change the dog...ha ha ha...
u r the best judge....ask the dog to do some work on it may be......
just kidding....
Posted on Dec 14, 2009
My tablet wont charge or turn on.. I have replaced the power cord cause a friends dog chewed up mine.. it work just fine till I replaced the power cord
Hi. Can you post your tablet's model part no.? It looks something like this near where you'll find the serial no. --> PDA01U-00101F
Apr 12, 2015 | Toshiba AT100-100 TABLET THRIVE
My dog chewed through the power cord. Can I replace this part without having to buy a whole new one? It's not mine someone was letting me borrow it.
You should be able to find a replacement at a hardware store. Take the plug end with you to get any assistance in determining the cord wire guage.
Apr 08, 2015 | Vacuums
Dog chewed end of power cord for compaq cq62 laptop right were the jack is. How can i wardire it?
If you cannot DIY or a friend that can help the putchase another power adapter.
If you wire the plug incorrectly the you could damage your laptop and which will cost a great deal more than the power adapter.
Apr 23, 2013 | Computers & Internet
My compaq presario cq62 wont turn on i bought a new power chord but it still does nothing
Shane, new power cord? Does this mean the old one was bad?
Do I assume you used a multimeter;
1) To test the voltage output of the AC adapter (Charger),
2) And had an assistant gently wiggle the cable TO laptop, and power cord TO AC adapter; to see if there was an intermittent reading on the multimeter?
[The Center Hole on the plug end of the AC adapter cable TO laptop, is the Positive connection. The outer cylindrical metal shell of the plug, is the Negative connection.
You should be reading 18.5 Volts DC.
An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. I have seen them on the checkout aisle racks, of large discount stores.
The Positive (Red) probe lead is inserted into the multimeter, in the Red hole that has DC Voltage next to it. (DCV)
The Negative (Black) probe lead is inserted into the Black hole ( - )
The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
IF there is more than one DC Voltage scale, the Function knob is set to the 0 - 50 Volt scale. { 0 to 50 ]
AC adapter checks OK?
Then check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the cable from the AC adapter is plugged into. (DC_IN)
AC adapter removed, ('Natch), and Battery.
Use a No.2 pencil, and it's eraser, to see if you can gently move the Center Pin, in the DC Power Jack.
ANY perceptible movement means replacing the DC Power Jack.
However good news. The DC Power Jack is NOT soldered directly to the motherboard.
It is a DC Power Jack that has wires coming from it, and the wires end in a small white plug.
This assembly is called a DC Power Harness,
All you have to do is partially disassemble the laptop, unplug the DC Power Harness plug from the motherboard, and replace,
http://www.amazon.com/Harness-COMPAQ-Presario-Pavilion-Series/dp/B004SFQA7U
USE AN ESD wrist strap, and connect it's alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving plate (Unpainted), on the table you are working on, and connect to it.
Or a large metal knicknack. (Unpainted)
Use a mutli-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up.
http://www.insidemylaptop.com/hp-g62-compaq-presario-cq62-disassembly/
(Just so you have it in case you need it for the future,
http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/ )
HP Support > Compaq Presario CQ62 series of Notebook PC's > Manuals > Service Manual, (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4188484&
Click on the first file listed -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC -
Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background)
AC adapter checks out, DC Power Jack checks out?
Check the Power On switch.
The Power On switch is pressed with the Power On Button.
The Power On switch is part of the Power Board,
http://www.ebay.com/itm/HP-G62-Compaq-CQ62-G56-Power-Button-Board-4EAX1PB0000-DA0AX1PB6E0-595204-001-/120845794823?pt=LH_DefaultDomain_0&hash=item1c22f87e07
This part separates the user from the tech. There are 6 wires in that flat cable. (I believe 6) There are 6 contact pins in the motherboard connector, for those 6 wires. TWO of those contact pins turn the laptop on. A tiny flat tipped Jewelers screwdriver, is used to MOMENTARILY touch the two contact pins.
{The Power On switch is a Momentary Contact Switch }
Laptop comes on you have a bad Power Board.
Laptop does not come on;
One or more Power MOSFETs may be bad, and may include bad Ceramic Capacitors (MLCC) for the Power MOSFETs.
Information using HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Yes, motherboard replacement
For additional questions, or to have me clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2012 | Compaq Presario Computers & Internet
Compaq Compaq Presario CQ62 white screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 01, 2012 | Compaq Presario CQ62-112TU
Dog chewed power cord. how do I repair
assuming this is a window air cond? It is not safe to use electrical tape, duct tape or any other kind of tape on a power cord to cover bare wiring. Many times I have cut the cord short enough to cut out the place where chewed and gone to a hardware store where I can get a new cord end that matches the wall plug and wire it in to the shorter cord. If this is not possible, you will need to either make a new cord or try to find a cord at an appliance supply house.
Apr 09, 2011 | Haier Heating & Cooling
My dog chewed the cord in half! ?? dog is ok
Yea yea yea ... blame it on the poor dog ...
Is this printer a 110 VAC into the device or is it powered by a transformer?
If by a standard cord, use any computer cord. If by a transformer, there is that possibililty you can repair the broken wire by removing the damaged portion and reconnecting the two ends. Pay attention to the marks on the wire (white mark or ridge or color of the conductor). Make sure the two wires are insulated from each other.
If you are not able to effect this repair yourself, or by a neighbor with a such skills, get yourself to the computer repair shop around the corner from where you live and plea your case. Expect to pay $15.00 for this repair job. If you require a new power supply, please check www.hp.com/support for your model, e-bay or Craigs List.
There are a few emergency ideas for you. If it is really really really critical and you can't find or make the repair ... you can always get a new, economy printer to use until you can get this one going again.
Thanks for your interest in FixYa.com
Feb 22, 2010 | HP PSC 1210v All-In-One InkJet Printer
Pwer adaptor wiring jack plug
try ebay the mite have some lala linda www.ebay.com
Jan 05, 2009 | HP Compaq nx6110 PC Laptop
Dog chewed cord
http://geeksquad.fixya.com/ThreadView.aspx?prdid=433382&thid=690168
Dog chewed cord
Posted by jnunez918 on Jun 20, 2008
My dog chewed through the power cord (luckily unplugged). Are there replacement parts available and I can't seem to find out to detach the cord from the unit.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are replacement parts available for the replacement of the power cord and to check your owner’s manual to see the schematics of the replacement of the cord. You can check with your local vacuum cleaner dealer in your area or you can call cust serv @ Bissell @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
