Question about JVC GZ-EX210 Full HD Everio Camcorder with WiFi Red GZEX210RUS
No Power Used once.... set aside. went to charge to prep for my mom using it. No chrg light came on and it doesn't appear to be getting any power to it to charge.
If your Charger is OK, then the problem is your units' battery was drained. Change your units' battery.
Posted on Apr 23, 2013
My RCA tablet wont charge. I have used 4 different charge cords.
the volts may notbe the same for the chrg you have... goto bestbuy just so youcan get the right style for that model plus try can check to see if it is changing
Jan 02, 2015 | Tablets & eReaders
I have a brand new i335 but when i want to charge it it doesn't turn on
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 10, 2012 | Nextel i355
Although when i press power it doesn't work ?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 08, 2012 | Sony VAIO VGN-TX670P/B Notebook
Doesn't start up
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory at the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 18, 2012 | Computers & Internet
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Apr 21, 2012 | Compaq Computers & Internet
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
New SKILSAW 5995 used once to cut 1/4 inch plywood, no problem. Several months pass and I went to cut a pine board, the blade touched the wood and stopped. I recharged the batteries and tried again, two...
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Aug 12, 2011 | Skil Saws
I got a old phone from my friend because my phone got broken. and when i went into the security code set up, i thought the security code was 0000. but it was wrong and it asked me about the puk codes and i...
You have entered the wrong SIM password so it is locked. You can unlock it easily. You have to call your network service provider and ask for PUK code. They can ask you SIM no. which is printed at the back of SIM card.
Then you can enter the PUK code and use the phone again.
Revert in case of any problem.
Jun 14, 2011 | Nokia Cell Phones
JVC GZ-EX210 Full HD Everio Camcorder with WiFi Red GZEX210RUS Logo
59 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
