Question about Canon lc730i 21047758 Fax
Canon lc730i want to forward incoming fax to email but do not know how to do it.
4 Suggested Answers
tech435
  • 284 Answers
SOURCE: faxes aren't being forwarded
to try to find out where they went check your fowarded email address. check your parameters in function-7-1-start then scroll down.
to shut down fax foward the other person was right function-7-4-start-5-4-start-1"invalid"-start-stop
any other questions feel free to ask.
Posted on Sep 11, 2008
  • 298 Answers
SOURCE: I have a Panafax DX-2000
Printout, Scan and send a .jpg of the scan as attachment, or sign up to Free internet FAX service and fax yourself the data.
Posted on Mar 26, 2009
  • 167 Answers
SOURCE: How do I forward incoming faxes from a Canon
The easiest way to do this is to contact your phone company to divert the calls directly to another phone number.(Call divert)
Posted on Oct 26, 2009
Canon lc 730i user manual
You may download a copy of the manual here.
Apr 16, 2013 | Canon lc730i 21047758 Fax
How do you change the time on a Canon LC730i fax machine?
Open all three One-Touch Speed Dial panels. Press 'Data Registration' button. Press down arrow until "5.Timer Settings" appears. Press 'Set'.
1.Date/Time Setting is displayed. Press 'Set'. Input date and time. Press 'Set'. Press 'Stop' to return to standby mode. This info can be found in your Reference Guide on page 5-8.
Nov 04, 2009 | Canon lc730i 21047758 Fax
How do I forward incoming faxes from a Canon Laserclass 2050P to another number?
Oct 23, 2009 | Canon LaserClass 2050 Plain Paper Fax
I want to send all incoming faxes to an email address instead of printing them
You can contact to the toll free number of the manufacturer...Engineer will change the setup of incoming messages..........
May 15, 2009 | Office Equipment & Supplies
How to fax forward?
You can set your product to forward incoming faxes to another fax number. When the fax arrives at
your product, it is stored in memory. Then your product dials the fax number you have specified
and sends the fax. If it cannot forward a fax because of an error (for example, the number is busy)
and repeated attempts to redial are unsuccessful, your product will print the fax.
If the product runs out of memory while receiving a fax, it will terminate the incoming fax and only
forward the pages and partial pages already stored in memory.
When using this feature, the product must be the one receiving faxes (not the computer) and the
answer mode must be set to Automatic (see Changing how the product answers incoming faxes).
To use fax forwarding
Press menu/enter.
2 Use the < or > button to select Fax Setup and press menu/enter.
3 Use the < or > button to select Fax Recv. Setup and press menu/enter.
4 Use the < or > button to select Forward Fax and press menu/enter.
5 Press > to select On or Off and press menu/enter.
6 If you choose to turn fax forwarding on, use the alphanumeric buttons to enter the fax number
where you want the fax to go, and press menu/enter to save your selection.
Apr 15, 2009 | HP LaserJet 3330 All-In-One Printer
Do Not buy Canon Copiers
What kind of Canon did you buy? What model? Who installed the copier and set up your network. Did you buy it from a Canon dealer. Also, dose the the copier ahave a fax PCB. I install Canons all the time and they run perfectly. It's only my oppion, I've been working on them for 18 years... It seems you bought one that did not have all the options loaded or you got a non-industrial model.
Nov 10, 2008 | Office Equipment & Supplies
Scanning to email; Canon LC730i
You need to network the printer via its ethernet port and you need an email server in that network to route the fax.
I got it to work at home using hmail (a free windows mail server).
Fax
http://www.twesalesusa.com/downloads/FAXDrv_G.pdf
http://www.twesalesusa.com/downloads/Network_Guide.pdf
I cant find the sending guide which I have in print, you will need that as the most important piece, but basically if you know basic email account setup, you should be able to go through data registration button on main panel and under system settings-> network settings I believe enter SMTP IP address of your internal email server. Another avenue for this would be to ask your ISP if they relay email for static IP subscribers. Qwest does and you might be able to point the fax directly to the relay but I haven't tested this (in lieu of the in home hmail server).
Oct 24, 2008 | Canon 730i Laser Printer
How to forward an incoming fax to another number with a canon laserclass 3170
Do you have the device connected to your network? If so, you can go to it's web management interface by entering it's IP address into your web browser's url bar. You will want to look under Add. Func., Fax Forwarding.
Jul 29, 2008 | Canon LaserCLASS 3170 All-In-One Printer
Canon lc730i 21047758 Fax Logo
50 people viewed this question
old marine
old marine
