Question about Casio Exilim EX-Z57 Digital Camera
Casio Exilim won't turn on when memory card is inserted
I have a Casio Exilim EX-S3 that I have for about 4 years. It has just started not turning on when I have the memory card inserted. I have tried other memory cards and they do not work either. It will turn on when I take the memory card out. Can you offer suggestions as to what the problem may be? Thanks.
  • 641 Answers
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Posted on Aug 22, 2007
    New Friend:
Tried looking for a bent pin but can't see anything also when the sd card is out the camera tuns on but the screen is all fuzzy and can't see any menu
Posted on Jul 07, 2013
I have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Jul 26, 2010 | Casio Exilim Card EX-S100 Digital Camera
MY DIGITAL CAMERE MEMORY IS FULL, WHEN I TURN ON MY CAMER IT SAID MEMORY IS FULL. I DON'T HAVE A CARD INSERTED IN BECAUSE WHEN I PUT THE CARD IN IT WON'T COME ON AT ALL. IT ONLY COMES ON WHEN I TAKE OUT OF...
camera's onboard memory is only 8MB, maybe 1 or 2 high resolution photo. delete the photo on the camera to clear error message and use only no more than 2 gig of sd card. It does not work with higher than 2 gig which is SDHC type sd card.
May 20, 2010 | Casio Exilim EX-Z55 Digital Camera
SD card not working on EX-Z1 Exilim cammera?
Are you sure you have an SD card, 2GB or smaller? The S600 will not work with the higher-capacity SDHC cards.
Jul 03, 2009 | Casio Exilim EX-S600 Digital Camera
Camera doesn't turn on with video card inserted or shows "error "
try inserting another piece of memory card. and format it. if the problem still persist, i suggest that your camera needs to be brought to the service center.
Dec 05, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio ex-z60 cannot read memory card
Make sure that the SD card you are using is either a SanDisc, Toshiba, or Panasonic. Those are the only cards that have been tested with Casio cameras. Also make sure that you format the card WITH THE CAMERA before you try and use it the first time. If it still doesn't work I would try resetting the camera and then you should have no problem.
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Casio ex-m2
Does the Camera have internal memory? I think you need the card it to get any where Check out the manual
Dec 11, 2006 | Casio Exilim EX-M2 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
474 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
