Question about Weber SPIRIT E-210 (NG)
Kenmore Cross Ray Gas Grill Model #16671 when i open all valves turns off all burners. Then I have to close the gas tank valve open it and i can start 2 or the burners right away after i open the 3 valve it starts to give a windy sound like flapping sound and then turns all burners off. Like it is was gettng or too much air or too short gas
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have a Kenmore 14116329 propane grill. The propane tank is full but when I turn on the burners very little gas comes out resulting in a VERY low flame. Is it the regulator or???
It is most likely the saftey check valve in the tank. The procedure is to:
  • Close tank valve.
  • Disconnect hose connection from grill to tank.
  • Wait
  • Reconnect hose connection from grill to tank
  • "Slowly" open valve on tank to release gas back into grill
Through on some steaks
If still a problem replace tank.
The check valve that can cause your problem drastically reduces propane flow in case of an accident and the lines are ruptured
Hope this helps?
Jul 03, 2017 | Kenmore Grilling
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Gas tank is full, burners are turned on high, but flame is very low
lProblem: Low flames on grill, tank is full.
Cause: These newertanks have a device inside that limits the flow of gas to preventleaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Closethe tank valve and remove the tank. Check the gas line for ANY objectthat could cause blockage. Open all valves on the grill to eliminateany pressure whatsoever. Close all valves and reattach tank. SLOWLYopen the tank not over 2 turns. Check for leaks. I just open my tank atiny bit but that is just me.
This late model gas grill service manual has more details on page 13
Jul 13, 2010 | Fiesta Advantis 1000 Grill
Low flame
close the air vents to the burners
Jul 05, 2010 | Weber Genesis Silver B Grill
Gas not coming out enough; flame not catching on to other burners
Cause: These newer tanks have a device inside that limits the flow of gas to prevent leaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Close the tank valve and remove the tank. Check the gas line for ANY object that could cause blockage. Open all valves on the grill to eliminate any pressure whatsoever. Close all valves and reattach tank. SLOWLY open the tank not over 2 turns. Check for leaks. I just open my tank a tiny bit but that is just me.
This late model gas grill service manual has more details on page 13.
Apr 28, 2010 | Weber Genesis Silver A Grill
I have a Vermont Casting 3 burner BBQ, Model VM400XBP, 36,000BTU grill that won't go above 300 degrees? How can I fix it?
It could be something as simple as a triggered safety feature within the gas tank itself. These new tanks will react to the gas leaving the tank at a high flow rate causing low burner temps. To remedy: shut off gas and remove tank. Open and close all valves on the grill. Reattach the tank and SLOWLY open the valve 2 turns. Then retry. See page 13
Apr 28, 2010 | Vermont American Tool Company VM600BSP...
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
Propane grill wont ignite
Well, it sounds like your grill is experiencing vapor lock. Vapor lock is basically air caught in the gas line and there is a relatively easy method to fix this. I want you to try this method and tell me what you get, ok? First, open the tank's valve, then open the burner valve and light the grill. Immediately after you see a blue flame, turn off the tank's valve, count to five and then close the burner valve. Repeat this procedure three times, the problem should clear itself.
If you are still experiencing problems, the regulator may be faulty and needs to be tested next, so go get a new regulator from your Lowe's and run the procedure again. If after all this, you are still experiencing the problem, let me know here. Good luck!
Jan 06, 2010 | Grilling
Our grill doesnt seem to be getting enough gas to stay lit. when you turn the burners on your hear the gas coming through for 2 seconds..then nothing, and it wont stay lit
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Sep 06, 2009 | Grilling
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Weber SPIRIT E-210 (NG) Logo
648 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
