Question about Siemens Computers & Internet
Fuel Injectors 6h4q9k546 db for 368 dt v8
All 8 is damadge
2006 1.4 mini one diesel. No fuel from tank to high pressure pump
have you had fuel system bled up correctly? check lines not damadged
Feb 11, 2015 | Mini Cars & Trucks
My 2010 Sebring has a rough idle and run before and after changing spark plugs. What else could it be?
Could be too many things for a rough running engine. This could be the o2 sensor, air or fuel filter, injectors or even the coil packs. If there is a CEL blinking on the db, you should diagnose the codes to locate an exact issue.
Apr 22, 2013 | Cars & Trucks
1980 Cadillac Biarritz 368 fuel injection
How about timing chain being worn & gears stripped ?
Put a timing light on it, then put the pick up on a wire
half way thru the firing order & see if they timing is
the same.
Feb 17, 2013 | 1980 Cadillac Eldorado
1988 C2500 engine stalled, cranks doesn't start.put starting fluid will start,checked power to fuel pump no power checked fuse to fuel pump it's good .could be ECM.
Remember that the relay only will send power to the fuel pump for only 3-5 seconds after the key is turned on. You will need someone in the cab cranking the engine over while you test the circuit to the pump. Make sure you are testing the correct wire. If the engine will start with starting fluid, then there is a fuel delivery problem. Connect a fuel pressure guage to the fuel rail. If you have the required pressure, then you may have a computer that is not grounding the injectors. If you have no fuel pressure, you may have a inoperative fuel pump or a clogged fuel filter.
DT
Aug 22, 2010 | 1998 Chevrolet C2500
Need location of coolant temp sensor so it can be replaced
Here it a pic of the CTS for the computercoolant temp sensor
(1) EVAP Canister Purge Solenoid
(2) Fuel Pulse Dampener
(3) Fuel Rail with Injectors
(4) Crankcase Vent
(5) Left Bank Ignition Coils/Modules
(6) Left Bank HO2S Sensor 1
(7) Engine Coolant Temperature (ECT) Sensor
(8) Fuel Pressure Gauge Test Connector
(9) Throttle Position (TP) Sensor
(10) Idle Air Control (IAC)
hope it helps if you need more info just ask!dont forget to vote on the answer thanks have a good day DB
Aug 19, 2010 | 1999 Pontiac Firebird
Does anyon know the size of the fuel injectors on a 1985.5 Porsche 944? I'd like to upgrade the performance
You will have to also consider Fuel pump delivery pressure to accommodate the Upgraded Fuel Injectors.
Reference archive Editorial write ups from Car Mechanics Magazine, as this topic has been covered in the past.
Regards,DT
Sep 05, 2009 | 1985 Porsche 944
Fuel in oil on 2002 chevy 2500hd duramax
THE DURAMAX ENGINE INJECTORS GO BAD AND SPRAY TO MUCH DIESEL AND IT FILLS THE CRANK CASE UP 200 THOUSAND MILE WARRANTY COMMON PROBLEM DON'T DRIVE IT ANY MORE IF U HAVE BAD INJECTORS.
Jun 21, 2009 | 2003 Chevrolet Silverado 2500HD
Computers & Internet Logo
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
