Question about Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack
Raymarine smart pilot st6002 backlight is too dim
Backlight as received is too dim
Get a new backlight, inverter is probably ok.
The way to check that the inverter is ok:
disconnect the backlight and if you hear a high pitched noise, the inverter is still good.
replacement backlight is available from a company called Being Seen Technologies.
there website is www.beingseen.com
Posted on Jul 04, 2009
No backlight on raymarine E120
You may have inadvertently turned the backlighting off. Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Jun 12, 2014 | Raymarine Ray 240 Modular Vhf System
Front display poising backlight and goes dim.
I believe this is most likely due to incorrect voltages at the display. If you have a meter and are familiar with working on electronics, check the voltage at pin 3 of cn501. It should be -28.5. If the voltage is very low, try changing C123 and C124 in the power supply. If the voltage is ok, check R925 and R932, these are both 10 ohm 1/8th watt.
Dec 13, 2017 | Aiwa AV-D97 Receiver
S1 pilot, on install burnt out seatalk circuit
You are still OK, if it smoked out of box, call Raymarine and yell and they should send you a replacement course computer. Also, there are two SeaTalk circuits, so maybe one still works? I have a replacement brain in stock if you like. 847-746-0100.
Jan 23, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
The backlight on garmin legend is dim - how do i brighten it
When the unit is on, press the bottom right side button on the GPS unit. A slider will appear to increase brightness, use your toggle to move the slider up.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 20, 2009 | Garmin eTrex Legend GPS Receiver
Need to find a replacement motor for my auto pilot pump. it is a CE M81120 motor. Any idea where i might be able to purchase one? Thanks Aj
as far as i know, the electric motor is not available. Replace it with a Furuno or Simrad pump (Acusteer) and you will have a sevice-able item.
Sep 21, 2009 | Raymarine Smartpilot St6002 S1 Hydraulic...
Installation raymarine st6002
The power cable of your 2106 acts as a data cable also. You should find additional unused wires on the cable. Locate the brown and blue wires. You will need to connect the brown wire to the "NMEA OUT +" terminal on the autopilot course computer and connect the blue wire to the "NMEA IN +" terminal on the course computer. Finally, connect the "NMEA OUT -" and the "NMEA IN -" to ground (preferably the same place that the Garmin is grounded (black wire). Be sure that the Garmin interface is set up for NMEA In / NMEA Out. That should get you going!
Feb 20, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
407 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
