Question about Pitney Bowes 9920 Plain Paper Fax
Fax machine will not let me put in the access code
I need a access code to recieve a fax
you have a fax machine or you have a fax program on your computer?if you have a fax machine you dont need access code.
Nov 27, 2013 | Brother IntelliFAX 1570MC Plain Paper Fax
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
What is the access code for the 9920 PB Fax Machine?
If the access code has not been changed it is 9920. If it has been changed, use ***1
Dec 10, 2009 | Pitney Bowes 9920 Plain Paper Fax
We have a model 9930 fax machine the power went out,and i everything reprogrammed for speed dial, but it asks for access code everytime,how do I stop that
Function 9, yes, access code is 9930, yes, press no until you get get to set access code, press yess. Press no to clear code, then press yes. press stop
Jul 08, 2009 | Pitney Bowes 9920 Plain Paper Fax
Always asking for an access code.
You will probably need a technician to set the machine back to it's factory defaults. Sorry
Jun 11, 2009 | Pitney Bowes 9920 Plain Paper Fax
How do we send faxes without having to put in code on a pitney bowes 9830 fax machine
go into service mode and clear all codes, reset machine and it will work
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
I need to put in access number to fax
Key in fax number press PAUSE twice then access code then start.
Sep 05, 2008 | Brother FAX-575 Plain Paper Thermal
Needs Access Code
on all these machines it is universally ***1
Nov 20, 2007 | Pitney Bowes 9920 Plain Paper Fax
Fax
An access code is normally set up by a person or company to prevent long distance faxes or phone calls by unauthorized users. The access code is a series of numbers to access long distance service. Check with your employer for the long distance code or check with you carrier to make sure that this service has not been put on your line by mistake.
Oct 08, 2007 | Brother IntelliFax-2820 Laser Fax
Wrong Date - no confirmation page - Access code
I have not worked on any Pitney Bowes before, but I am sure you can find a manual on their website. Sounds like you might need a firmware update. Also try justmanuals.com
Jun 01, 2007 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes 9920 Plain Paper Fax Logo
16 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
