Question about Orion1934 19" TV
Broken cable port
I came back to school after my vacation was over. I was moving my television and noticed that the port the the cable wire plugs into was loose in the back of the tv. I turned on the TV to see if I can still watch it, but I get no signal. I kept tinkering with the port to see if I could get a signal but it just broke off. I think It needs to be repaired and I'm stuck at school for another 2 months and I don't know what to do.
  • sbm035 Mar 13, 2009
    Another question where can I get that repaired?
    Again I'm at school with no car.
  • 89 Answers
Tuner needs to be repaired, Usually the "F" connector can be re-soldered into the tuner housing or replaced
Posted on Mar 12, 2009
Br450 has no spark, less than 50 hrs run time. 2 days ago ran great. Checked spark w/ plug removed, even held while pulling...No Shock felt, even tried w/ new plug. Suggestions?
Yeah, on the carb linkage, where the cable from the speed lever is connected, notice when you move the lever on the bar how it moves another lever on the cable connection at carb. Now notice when you move the lever to stop position that it will move a little bent wire connected to the black wire that goes under the flywheel. This bent wire is the shut off when it is grounded out by the movement to ground of this little bent wire. The intire bracket may be loose and letting it ground out and is why you have no fire to the plug. Just be shure that little bent wire isn't touching anything to ground it.
May 12, 2017 | Cars & Trucks
L100 desktop
Lost a power cable?
Like it was walking down the street one day, and the power cable fell out of it's pocket?
Or do you mean came loose?
Or in YOUR estimate, that one power cable coming from the Power Supply, is bad?
The first one I was trying to be funny.
I'm serious about the last two.
http://www.geeks.com/details.asp?invtid=ASL100-UA380A-R
Hmmm, okay let's try this another way,
(Notice I didn't even go to Acer Support. With the info they give the consumer, it isn't worth the trouble. Also tells you a lot about this computer company.........)
http://www.ebay.com/itm/Acer-Aspire-L100-Motherboard-MB-S6909-003-MBS6909003-/120919471509?pt=Motherboards&hash=item1c275cb595
Oh, I see................
http://www.amazon.com/Acer-Power-Aspire-Adapter-Supply/dp/B004PYZSCC
I just got schooled.
Don't believe there are any power wires inside to connect, Christina.
Power is from an external power supply, that plugs into the computer.
(Like a laptop)
The only wires in my estimate, is;
A) The small audio wire from the optical drive (CD/DVD drive) to the motherboard, (Close to the Blue VGA port)
B) The Front Panel wires,
C) USB Front Panel port wires to motherboard
D) Media Card Reader wires to motherboard
E) Harddrive and optical drive data cables to motherboard. (One each)
(The front of your computer is the Front Panel)
Computer not coming on?
See if the external power supply is good.
Voltage coming out is supposed to be 19 Volts DC.
The plug end on the external power supply;
The center hole is the Positive ( + ) connection.
The cylindrical metal shell on the outside, is the Negative ( - ) connection.
Multimeter positive ( Red) probe lead goes to center hole.
Negative ( Black ) probe lead touches outside cylindrical metal shell.
Multimeter positive (Red) probe lead, plugs into red hole on multimeter, marked DCV.
Negative (Black) probe lead only has one hole (Black), to plug into.
Function knob is set to DC Voltage. DCV.
If just a symbol, the symbol is a dotted line over a solid line.
If more than one scale, set it to the 0-50 Volt scale.
(0 to 50 Volts ]
An economical multimeter is about $5 to $12.
Auto parts stores have them. (Although probably more expensive)
I have seen them on checkout aisle racks, at major discount stores.
While checking the AC adapter, have an assistant gently wiggle the cable, from the AC adapter TO laptop.
See if the reading on the multimeter fluctuates. If so you have a broken wire in that cable.
Have the assistant also gently wiggle the power cord.
Or take down to nearest 'Mom and Pop' computer shop, (Small store), and have the resident tech check it for a few bucks
Could also be the Power On switch.
This is located inside the plastic assembly, of the power on button.
They go bad, and do not leave a forwarding address ;)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Acer Aspire L100 PC Desktop
My ipad wont charge or come on
it has to be on for your pc to read it,
you need to charge it but sounds like your ac adapter is dead or the charging port on the side of the ipad itself
plug in the adapter then move the cord around to see if theres a break in the wire inside the cord, and move the plug up and down where it connects to the ipad (push it in and out and side to side)
if that dosen't work take it to the apple store and they'll check both for free
Aug 22, 2012 | Apple Hard Crystal Back Cover Clear Case...
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    How do you repair the lamp cable on a Minolta EP3170
    Are you talking about the power cable that powers the scan lamp Or the cables that move the scanner bar back and forth?
    If you mean the cables that move the scanner then nothing can be done. These are of a specific length and would have to be duplicated perfectly in order to keep from ending up with out of focus copies. The power cable "might" be repaired if it had a broken wire by opening up the insulation and resoldering the broken wire then taping up the cable. Just be sure the machine is unplugged before working in this area as some older Minolta's like this use neutral line switching so there may be power applied to the cable anytime the machine is plugged in.
    Jan 25, 2010 | Office Equipment & Supplies
    Scanner
    Most lexmark all in one printers require that the drivers be installed first before plugging it into the USB port. If you were moving it, their could have been a chance it didn't get placed back into the same port it was before the move. To solve this issue, either plug the printer into a different USB port or reinstall the printer. I would try option A first, you will know when its correct when A it prints and B you dont recieve a notice on the screen for a driver request.
    Feb 23, 2009 | Lexmark X4270 All-In-One InkJet Printer
    I get no channels wen i plug in my cable wire into the cable jack
    First, I would change the cable that comes from the wall to the TV.
    Plug the cable into the cable port, then go into the menu of the TV. Go to the channel setting and go down to where it says "CABLE YES/NO"and change it to cable YES. Then try to re-autoprogram it.
    If there are no channels found after that, then you may have an issue with the tuner.
    Jan 07, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    Tv hookup with cable line
    there maybe a loose connection in the tv (connection port) or cable is broken
    Oct 31, 2008 | byD sign d:4232 42 in. HD-Ready Plasma...
    Laptop wireless hook up
    I just got your messages, looking at the details of your laptop it has a build in wireless so as you have noticed since its working now, you won't need to purchase a adapter for the laptop since it already has one build in.
    Let me know if you need assistance with anything else.
    Aug 14, 2008 | Linksys Wireless-G WRT54G Router
    Sanyo LCD TV DP32746 no picture
    Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. Moniserv.com for replacements.
    Goodluck guys!
    Mar 17, 2008 | Sanyo DP32746 32 in. LCD Television
    Orion1934 19" TV Logo
    147 people viewed this question
    Top Orion Televison & Video Experts
    wayne chamberlain
    Jerry Greenberg
    Jerry Greenberg
    Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
