Question about Sewing Machines
Elnasuper The machine runs as soon as you plug it in. Have a new foot pedal switch....but it still runs all the time. What's wrong??
  • 980 Answers
SOURCE: I have and old Bernina 830 and am trying to adapt
unless the new harness and control is for a new style computerized machine the control should be the same, the different size plug is baffling me
Posted on Jun 26, 2010
SOURCE: singer 7258display screen shows dashes..machine wont respond to foot pedal or anything..no buttons affect machine
sounds like part of the computer is going out & needs to be checked
Posted on Mar 27, 2012
  • 1564 Answers
SOURCE: my Hyundai 60 stitch machine runs as soon as I plug it in foot pedal wont work if I press it the machine speeds up HELP
Sounds like you need a replacement. Or the food pedal needs a good cleaning.
Posted on Aug 05, 2012
  • 1564 Answers
SOURCE: My Elnasuper makes a whirling noise but none of the moving parts will move. Light works and I tried the foot pedal on another machine and it is fine. Any ideas?
This is a machine with the motor and belts hidden inside right? Your belt is broke. While you can replace yourself... it's likely that it threw the machine out of time... and it is very easy to through the machine out yourself when you replace the belt yourself (ha! ask me know I know!)
If everything works when you use the hand wheel... take it in and have the belt replaced.
Posted on Sep 17, 2012
solarmama
SOURCE: The machine runs constantly when
My machine is acting quirky too. I have a Singer Professional 2010 and it just started jumping from side to side when in straight stitch, also it won't turn off when I take the foot off the pedal. I don't know what the problem is. I have a whole pile of stuff to finish for Christmas and now I'm in a real bind!
Posted on Dec 18, 2012
Foot pedal surges
make sure the foot pedal is securely plugged into the machine,, the foot pedal may need to be checked to see if there is something wrong with it.
Jun 09, 2015 | Sewing Machines
When stepping on pedal, my juki 5550 straight sewing machine, why will the machine not run? Light works but not machine
there could be something wrong with the foot pedal, it may need to be serviced or replaced, or there could be something wrong with the plug where the foot pedal plugs into
Feb 20, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Why is it that as soon as I plug in the foot pedal the machine starts?
The foot control is a simple device with a resistance value that, as the foot control is depressed, the value diminishes and the machine runs faster. The cause of an immediate run condition will be the result of the following:
1. The cable or plug has been damaged so as to connect both wires to create a maximum run state. 2. Most common to the foot control itself is that the actuator for the slide resistor is broken and stuck in the max run spot as well as having been disconnected from the on/off micro switch. 3. The foot control has been taken apart and improperly assembled. SewTechnical Home
Oct 17, 2014 | Bernina Virtuosa 150
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
Aug 03, 2012 | Elna Sewing Machines
What's your problem?Have a TOYOTA EZT9000 and it seems to have slowed quite a bit. Does it need oil? If so, where do I put it in?
there are other things that can cause the machine to slow down
like the motor, foot pedal, have you checked these things first
1. is the power cord plugged into the outlet securely
2. is the power cord plugged into the machine correctly
3. is the foot pedal plugged into the machine correctly
4. is the cord to the foot pedal caught in the foot pedal
if none of these are the problem, then the machine needs to be serviced
to see why it's running slow
May 01, 2012 | Toyota EZT9000
Foot pedal error
Yep same thing .....the thing is possessed started running by itself when I was at the iron. Dealer said never heard of such a thing and acted like it was me. Also will not stop sewing when take foot off pedal. Dealer charged me $95 to clean machine and said nothing wrong with foot pedal. Ugh. Has anyone replaced foot pedal and found the problem to stop properly?
Mar 15, 2012 | Janome Memorycraft 6500P Computerized...
Wiring a foot control pedal for Singer Slant-o-Matic 401G sewing machine, banana socket. The machines listed are newer models and my 401 is not listed.
Faboulous machine the 401 and the best machine ever made, in the UK if I remember the two red wires go to the right hand pin and thw two blacks go to each terminal, when you rewire the plug which is fidly undo the stop motion, when you plug the machine in if it runs on without touching the foot control change the two black wires over, to rewire the foot control there are only two wires, you can't go wrong.
Jun 11, 2010 | Singer 7422
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
