Dog chewed end of power cord for compaq cq62 laptop right were the jack is. How can i wardire it?
  • 32,281 Answers
If you cannot DIY or a friend that can help the putchase another power adapter.
If you wire the plug incorrectly the you could damage your laptop and which will cost a great deal more than the power adapter.
Posted on Apr 23, 2013
SOURCE: Power Trouble
Hi!
First, you need to check the one that you got for replacement is the correct adapter for your system. If it matches with the old one, make sure that the ac adapter light (LED) is on when you plug it the wall outlet only. When you plug it in the portable and if your ac adapter LED blinks out (turns off) then the motherboard needs to be replaced or else the ac adapter is not working and needs another replacement. Call Dell and have it replaced if you just bought it.
Hope this helps!
Karlox™
Posted on Dec 19, 2007
toddg
  • 171 Answers
SOURCE: neeed powercord for 557s laptop
The Balance CN6555 PC Notebook is actually an ECS (Elitegroup Computer Systems) 557. Their website can be found at
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=3&TypeID=13&DetailID=479&DetailName=Feature&MenuID=58&LanID=9
The power cord may be found at most electronics stores. These are not all that hard to find.
Posted on Sep 24, 2008
  • 262 Answers
SOURCE: pwer adaptor wiring jack plug
try ebay the mite have some lala linda www.ebay.com
Posted on Jan 06, 2009
  • 1481 Answers
SOURCE: My dog chewed my power cord. Dh
ask the dog.....!!!
ok sorry jokes apart...
was the battery working before ur dog helped u out...
remove the power cord and check how long ur battery can hold on till it dies down...when ur notbook is ON
if it holds for more than 10 mins then the battery will charge if the power cord gives it enough power to charge, else u may have a power adaptor that gives enough for notebook to work but not enough for the battery to charge at the same time....
u may have to change both the adaptor and battery....or else change the dog...ha ha ha...
u r the best judge....ask the dog to do some work on it may be......
just kidding....
Posted on Dec 14, 2009
SOURCE: laptop overheated
Try to remove battery, wait at least 10 seconds, than insert it back and see if it turns on.
Posted on May 04, 2012
How do i hardwire Compaq cq62 power cord. Dog chewed the end of mine off where the jack is
Most likely there are two wires a + and - power wires.
If you strip the broken ends of the wires on the plug and the end of the broken cable then you can solder the broken ends of the wire together. make sure the colors of the wires match and the wires are insulated so they do not short against each other.
Apr 23, 2013 | Computers & Internet
Laptop keyboard does not work after dog laid on computer
Tell dog to grab it's allowance, and buy you a new laptop
NO?
Then protest around the dog daily until it does
(No, you have to feed it)
[Hold the dog's chew toy for ransom. Chew on it a little bit so dog will get the message.
"Hey! Ain't kidding around here! Laptop or I keep this!" ]
OR,
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Press the Power On button, and hold it in for a count of 10 seconds.
(And I mean 10. Count; 1001,..1002,..1003,...etc)
Let go of the Power On button. Do this procedure two more times.
Reinstall Battery, THEN reattach AC adapter to laptop, and THEN plug AC adapter into power.
WAIT 1 minute,....turn the laptop on.
Post back in a Comment.
Regards,
joecoolvette
[Merry Christmas to all who are celebrating it! ]
Dec 25, 2012 | Compaq Computers & Internet
I have compaq cq62 do i need vga adapter
Yes, you either need an adapter sold at most places like best buy, amazon, newegg, etc. or a changeover cable most likely available at those same places.
Dec 15, 2012 | Compaq Presario CQ62-215DX Laptop
My compaq presario cq62 wont turn on i bought a new power chord but it still does nothing
Shane, new power cord? Does this mean the old one was bad?
Do I assume you used a multimeter;
1) To test the voltage output of the AC adapter (Charger),
2) And had an assistant gently wiggle the cable TO laptop, and power cord TO AC adapter; to see if there was an intermittent reading on the multimeter?
[The Center Hole on the plug end of the AC adapter cable TO laptop, is the Positive connection. The outer cylindrical metal shell of the plug, is the Negative connection.
You should be reading 18.5 Volts DC.
An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. I have seen them on the checkout aisle racks, of large discount stores.
The Positive (Red) probe lead is inserted into the multimeter, in the Red hole that has DC Voltage next to it. (DCV)
The Negative (Black) probe lead is inserted into the Black hole ( - )
The Function knob is set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
IF there is more than one DC Voltage scale, the Function knob is set to the 0 - 50 Volt scale. { 0 to 50 ]
AC adapter checks OK?
Then check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the cable from the AC adapter is plugged into. (DC_IN)
AC adapter removed, ('Natch), and Battery.
Use a No.2 pencil, and it's eraser, to see if you can gently move the Center Pin, in the DC Power Jack.
ANY perceptible movement means replacing the DC Power Jack.
However good news. The DC Power Jack is NOT soldered directly to the motherboard.
It is a DC Power Jack that has wires coming from it, and the wires end in a small white plug.
This assembly is called a DC Power Harness,
All you have to do is partially disassemble the laptop, unplug the DC Power Harness plug from the motherboard, and replace,
http://www.amazon.com/Harness-COMPAQ-Presario-Pavilion-Series/dp/B004SFQA7U
USE AN ESD wrist strap, and connect it's alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving plate (Unpainted), on the table you are working on, and connect to it.
Or a large metal knicknack. (Unpainted)
Use a mutli-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up.
http://www.insidemylaptop.com/hp-g62-compaq-presario-cq62-disassembly/
(Just so you have it in case you need it for the future,
http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/ )
HP Support > Compaq Presario CQ62 series of Notebook PC's > Manuals > Service Manual, (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4188484&
Click on the first file listed -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC -
Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(The file is downloading in the background)
AC adapter checks out, DC Power Jack checks out?
Check the Power On switch.
The Power On switch is pressed with the Power On Button.
The Power On switch is part of the Power Board,
http://www.ebay.com/itm/HP-G62-Compaq-CQ62-G56-Power-Button-Board-4EAX1PB0000-DA0AX1PB6E0-595204-001-/120845794823?pt=LH_DefaultDomain_0&hash=item1c22f87e07
This part separates the user from the tech. There are 6 wires in that flat cable. (I believe 6) There are 6 contact pins in the motherboard connector, for those 6 wires. TWO of those contact pins turn the laptop on. A tiny flat tipped Jewelers screwdriver, is used to MOMENTARILY touch the two contact pins.
{The Power On switch is a Momentary Contact Switch }
Laptop comes on you have a bad Power Board.
Laptop does not come on;
One or more Power MOSFETs may be bad, and may include bad Ceramic Capacitors (MLCC) for the Power MOSFETs.
Information using HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Yes, motherboard replacement
For additional questions, or to have me clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2012 | Compaq Presario Computers & Internet
Compaq Compaq Presario CQ62 white screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 01, 2012 | Compaq Presario CQ62-112TU
Dog chewed power cord. how do I repair
assuming this is a window air cond? It is not safe to use electrical tape, duct tape or any other kind of tape on a power cord to cover bare wiring. Many times I have cut the cord short enough to cut out the place where chewed and gone to a hardware store where I can get a new cord end that matches the wall plug and wire it in to the shorter cord. If this is not possible, you will need to either make a new cord or try to find a cord at an appliance supply house.
Apr 09, 2011 | Haier Heating & Cooling
My dog chewed my power cord. Dh "spliced" and taped for now. The laptop will work with power cord, but battery will not hold ANY sort of charge. Is the problem my cord or the battery now?
ask the dog.....!!!
just kidding....
Dec 14, 2009 | Dell Latitude D600 Notebook
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Pwer adaptor wiring jack plug
Jan 05, 2009 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
David Payne
David Payne
