Question about Alpine IVA-D300 Car DVD Player
Dvd player not working
What wire color is the resistance and how many volts is it?
  • Rob
    Rob May 11, 2010
    "what wire color is the resistance" -- Can you be a little more clear, or describe the problem you are having?
    Example: I have an "X" model car DVD player. There are 33 wires in the harness that are connected to "X" DVD player. What is the purple wire for?
    or
    Does this unit run on 13 VDC?
    Thanks
You just need to hook up the foot brake wire (yellow and black) and hook up the parking brake wire (yellow and blue (looks green) ) set the parking brake then press and release the foot brake and your dvd picture will play
Posted on Apr 16, 2009
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
, 1-need schematic to rewire a lorex color camera model no:MC7555R i have five wires coming out the back of the camera 1'
The RED wire is your 12 volt power "positive". The BLACK wire is your 12 volt power "negitive" The YELLOW wire is your camera video. The white wire is your cameras audio & the copper wire is shielded ground.{Davesajak}
May 01, 2012 | Lorex SG6153 / Weather Resistant Mini...
I have a proline dvdp920w ,the fault is the screen goes white the sound still plays
Screen goes white maybe moisture and condensation problem. But may have something to do with contact resistance on the 220 volt supply for LCD tin oxide. Contact resistance need an impact to shift the contacts to restore low resistance contact. Have experience to restore white screen by gently pat the sides of the device.even though Its a cheap fix; but use a fan to lower moisture in your room will fix it permanently.
Nov 21, 2010 | Panasonic DVD-LS55 Portable DVD Player...
AVX-P8DVD need to know how to bypass the parking break safty feature
Take the Park Wire, via a 100 - 1000 ohm resistor, to stop any potential damage if wrongly connected, AND this lead is taken, either to + 12 volts DC, always ON... or - 12V DC or Earth. Some also work through the Stop Lights Bulb resistance... But I am sure you get the idea.
Mar 02, 2010 | Pioneer Car DVD AVX-P8DVD - Premier 6.5"...
Background color is orange instead of blue, color is messed up
Usually this problem is a simple one to find out.Are you wires working correctly.If they are not,open up the box and,if you are a professional so I dont get sued for some accident,try to splice the wires back.If your not a pro take it to the retailer and have it fixed.If it is not the wires,I would check your color settings option in the DVD options menu.Check your red blue green balance and make sure they are correct.
Mar 24, 2009 | Philips DVP5990 DVD Player
Resister burnt
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks. mikeadams110@yahoo.com
Oct 02, 2008 | RCA DRC8335
KVT 617 CD/DVD "reads" but only audio from tuner
Ok, so I called Crutchfield, where I had purchased the unit, and the guy there said this is a common thing. Believe it or not, it IS the wiring. The guy said the blue wire on the harness needs to be connected to the blue/white wire on the Kenwood unit. Which is weird, since it's usually color-coded. He said the blue wire is a 12-volt amp wire, which works with the tuner, but when you take it off tuner, it kills the 12 volts and so you get no sound.
I haven't fixed it yet to be sure it works, but I thought I'd post this anyway, in case someone else is waiting on this. I'll post again if it doesn't work. :0)
Jan 29, 2008 | Kenwood KVT-617DVD Car DVD Player
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Alpine IVA-D300 Car DVD Player Logo
169 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
