Question about Panasonic TC-32LX70 Television
Power issues with panasonic tc32lx70
I have seen a few posts in regards to the same issue others have had with the unit not turning on..just the power light blinking. The only fix we have is to unplug the tv and then plug it back in. This happens every few days and the wife is thoroughly annoyed.
Has anyone been able to fix this and how much did it cost?
  • JIMJJJ42 Mar 24, 2009
    I have the same problem. Every few days the TV kicks out and has to be reset by unplugging it. Does anyone have a solution?
  • Anonymous Mar 27, 2009
    Same issue here. Going to call Boscov's since I purchased an extended warranty.
You need to go to Panasonic dot com search for TC-32LX70, go to software updates. Use a blank SD card and format it save the firmware file SDDL.SEC to it. Carefully open the "service panel" you may need to remove the entire back case? since it seems the frame is holding the service panel down. 1)power on the TV
2)insert the SDcard with firmware update into the rear(lx70) or the sdcard slot on the side(lx700)
3)follow the on-screen instructions.
4)when it's finished, remove the SD card.
turn off or unplug for 30+ seconds
5)power on.
6) perform the first time setup.
Posted on Feb 25, 2011
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
When turning on my Panasonic SA-HT940 the code f61 dispalyes and the unit turns off.
This is most likely a power supply problem.
F61 for model SAHT75 = Power amplifier output error or power supply circuit error.
Supply voltage for IC501 (Power Amplifier).
Approx. +60.0V dc at pins 3 & 20.
Approx. -60.0V dc at pins 4 & 21.
A qualified engineer may check the above voltages.
Another possible solution might be to hold down the power button until the unit restarts itself a few times, and/or before-hand unplugging the unit from the outlet.
Please be careful when working on any electronic device and let me know if you have any further questions.
Thank you for using Fixya and Good Luck
Apr 21, 2008 | Televison & Video
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
Blinking power light
call panasonic if there are that many posts maybe it is a recall issue and they should know about it.
Oct 03, 2017 | Panasonic Palmcorder PV-DV52 Mini DV...
Panasonic TC-32LX70 Television Logo
587 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
