FixYa.com
Tags:
Garmin Quest GPS Receiver
Garmin Quest GPS problem
posted by ilya12000 on Aug 04, 2007
Hello everyone,
My Garmin Quest does not receive signals of satellites, i'e I can turn it on, all functions are working, but it is not able determine his position. It is "searching for satellites" all the time and doesn't find them. I tried it outdoor in the open field, so it is not the matter of low signal.
Does anybody could help me with it or at least to advice some repair shop for repair out of warranty (better in Toronto, but I could send it to another place).
Thanks in advance,
Ilya
Comment by ilya12000, posted on Sep 24, 2007
Thank you Guest and Inegrin,
I've seen only today the answers and will try to do it later.
Thankis again,
Ilya
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 01, 2008
FixYa! (100)
irishlineman
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Thanks for the info, I have done as suggested and it has worked although you have to be very accurate with the soldering iron not to short out the electrical connections on the PCB while resoldering the aerial connection. Another solution to the problem if the thoughts of delving into the innards of your Sat-Nav scare you is to purchase an external aerial for your Sat-Nav Garmin product number 00-10702-00
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
inegrin
Rating: 95%, 3 votes
The above solution works even for the case when acquisition performance gets degraded. In my case it would take a very long time to acquire if at all. When removed the antenna,the gold piece remained inside the antenna as it should but eventual broke free after three disconnects of the antenna connector (which by the way takes a little force to separate the gold connector). After removing the back of the patch which just held on with adhesive, I soldered the patch side of the connector back as described above the unit began to work as new. My guess is the solder connection was either cold or beginning to separate causing degraded acquisition performance
Solution #3
posted on Aug 21, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
I have had the same problem. It is the aerial. Garmin have not madeit very strong. I would assume it is that as mine has done it now for the 2nd time. If you undo the 2 screws on the right hand side and remove the small bit of plastic to the right o the aerial the aerial should slide out. If the little golden piece is left behind, that is the problem. it needs to be soldered back on to the aerial. NOT a big deal for someone who can handle a soldering iron.
Troy
Can you Help with these GPS Devices problems?
Unlock certificate #
Trying to unlock 2009 City... Answer This...
registration of product
Quest - Garmin says (GPS is... Answer This...
No {post code directions
No {post code directions Answer This...
Garmin Quest 1 won't start up
I took my quest out of my... Answer This...
Garmin Quest1 map loading...
My Quest has 245mb of memory... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
