Question about Belling XOU252 Electric Single Oven
Oven wont work but clock still works
Whilst cooking my belling xou252 oven tripped the rcd fuse on my circuit board and stopped working . when i reset the fuse my oven came on for a minute or so then tripped again . on resetting the fuse for a second time the oven failed to work with only the clock light working . is this a problem i can repair or will i be looking at purchasing a new oven . help anyone ???????
I have a belling oven, model number X0U178. Oven and grill is not working and the fan is not coming on. Changed fuse in fuse spur but it is still not working.
Posted on May 09, 2009
    Guru:
  • 462 Answers
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Posted on Mar 12, 2009
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Smeg oven stopped working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 27, 2012 | Smeg Ovens
How do I set clock on Belling Synergie Multi-funtion oven (xou270)?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Jan 30, 2010 | Belling XOU252 Electric Single Oven
Can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Apr 18, 2009 | Belling XOU252 Electric Single Oven
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Instruction Manual Needed?
Hold cook time button and stop time button together and while both buttons pressed in, use + and - buttons to set time.
regards Paul.
May 10, 2008 | Belling XOU252 Electric Single Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Belling XOU252 Electric Single Oven Logo
563 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
