Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Door indicator prevents microwave from starting
When attempting to start the microwave using EasyMinute Start button, the microwave beaps three times and won't start. If I set the timer and press Start, the word DOOR is displayed on the front panel and the microwave beeps 3 times and does not start. How is the door open indicator detected? I replaced the electronic control panel but that did not work.
  • 1 more comment
  • Phil Weeks Aug 07, 2007
    Thank you for the advice. The schematics helped a great deal. It showed that I had while replacing the control board, I inadvertently connected P2 instead of P8. The P2 connections are for control of the lower oven in a microwave/oven combination model.
    All set.
  • Teckie Teck Feb 28, 2008
    I tried to change the door switches and tried the control board and all my connections still giving door on display and not working
  • rccamping2 Sep 06, 2008
    Door indication comes on when trying to start microwave and microwave will not come on.
  • 5,911 Answers
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Posted on Aug 04, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 07, 2007
    Glad to hear you're up and running again.
6ya staff
SOURCE:
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
Jun 12, 2017 | Whirlpool Microwave Ovens
When I attempt to use microwave it will sometimes not start from hitting the start button. The message on control panel screen say to open and close door. This does not work.
You have defective door switches, most of the time you have 3 of them. Should replace them all. But check to see if they work first..
Nov 09, 2015 | In Microwave Ovens
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
I have danby dmw112 1100 watts microwave that will not cook
i have power and light is on can not press any numbers or start button or any other button.it keeps on peeping steady
May 30, 2010 | Danby DMW112 Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
364 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
