Question about OCE 3140 Copier
Code on CM3522 OCE Copier/Printer
Our screen has a funnel looking object at the bottom of the login screen with red ink coming from it. When I press it, P7 appears on the screen. What does this mean. Also, our pictures are printing with what looks like a red sunburn on people's faces.
  • 3230 Answers
SOURCE: 0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Posted on Jul 24, 2009
  • 118 Answers
SOURCE: Oce vs. Xerox Recommendation
I can't speak for the OCE model, but I have worked on the WCP 7345 (I'm a trained Xerox tech), and I find them to be very reliable when it comes to recommended repair cycles and overall wear-and-tear of consumable parts.
Posted on Aug 21, 2009
Testimonial: "Thanks, that's the kind of advice I'm looking for. "
  • 20 Answers
SOURCE: What is error code 06112 ?
oce is a variety of different model of copier send me the picture of your copier then i can tell what model is it and what is the real problem low_toner@yahoo.com
Posted on Aug 30, 2009
  • 149 Answers
SOURCE: How to change OCE CM3522 imaging belt
transfer belt or imaging unit? First, you need a new one
Posted on Dec 25, 2009
  • 149 Answers
SOURCE: Oce CM3522 color copier won't print all of a
there is no bypass on this machine, the counts are reset by the machine thru fuses in the imaging units. If this is in error, there is a bigger problem, pls call a tech
Posted on Oct 05, 2010
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Oce Varioprint 6250 is telling me I have paper in the Preheat Unit and TTF. Everything is cleared but it won't reset.
To reset turn OFF tghe copier press and hold the Utility key and turn ON the copier and wait then the display scree trouble reset.Touch the screen and turn OFF the copier,wait 1 minute and turn ON.
Feb 20, 2013 | OCE Office Equipment & Supplies
OCE plotwave 300, error code 22509. Printer won't print.
PLC Connection lost. Get your Oce technician to upgrade you to the latest supported software level.
Oct 31, 2011 | OCE 3140 Copier
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
How do you reset the oce cm3522 fuser assembly error code
Only a qualified tech can do this. It's a safety feature since the fusers run hot and the maker's don't want their machines to start fires.
Feb 03, 2011 | Office Equipment & Supplies
Oce CM3522 color copier won't print all of a sudden. It has arrows pointing to all four imaging units to be replaced but WE JUST DID THAT LESS THAN A WEEK AGO. Anyone know how to bypass the error...
Sep 13, 2010 | OCE 3140 Copier
Nov 30, 2009 | OCE Office Equipment & Supplies
Aug 06, 2009 | OCE Office Equipment & Supplies
24 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
