WF448AAP XAA shipping bolt
2 Suggested Answers
  • 5 Answers
SOURCE: I am moving across the
go online to smsung.com. you should be able to buy any parts you need through them.
Posted on Sep 26, 2010
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
I have a WF448AAP/XAA washer and is leaking from the bottom, what it be?
Could be the bottom seal of the drum, a leaky hose or the pump that discharges the water out of the drum during rinse cycle. If it seems to leak while filling and/ or operating my bet would be the drum seal.
Nov 27, 2014 | Washing Machines
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
It will not start and it is brand new.
If not at all installed. Check & remove transit bolts. Look for any snapped wire connections.
If already installed and used for some time, check whether water is flowing into your machine. No on lights "ON" check power and fuse inside th m/c.
Mar 30, 2010 | Samsung WF448AAP Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
