Question about Bosch Washing Machines
Excessive vibration on spin cycle.
I have a Bosch Nexxt Front Loading Washer. The model number is WFMC3200UC. There is excessive vibration on spin cycle. I have checked the leveling of the machine and it is ok.
  • 4,738 Answers
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Sep 18, 2009
My bosch nexxt washer model wfmc3200uc/01 vibrates excessivelyrics and moves across the floor on spin. I have balanced and tried everything. Any advice on parts that can be replaced or where to start
This probably aint it, but my front loader did that, and it turned out to be a bracket that they install for transport. It connects to the tub and keeps it from bouncing while in transport. If it is connected, remove it and try it then.
Sep 06, 2015 | Bosch Washing Machines
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Excessive vibration while on spin cycle.. front loading washer
first make sure the washer is level.next check the floor to see if it gives,try placeing a 3/4 " plywood under the washer.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Excessive vibration
hi! make sure the machines shock absorbers are ok and that the ballast block is intact and ancored down.
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
1,208 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
