Question about Dryers
Kenmore elite dryer 79680512900 cooling buttton staying on and dryer will not heat
Cooling button staying on and the dryer will run but will not heat up
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
huuum
  • 750 Answers
SOURCE: Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Posted on Jan 23, 2009
  • 175 Answers
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Elite Dryer button won't stay on - no heat
There is a switch on the motor, (centrifugal) that bypasses the push to start once the motor is turning. It is in the heat circuit also. Look there first...Eric
Posted on Jun 15, 2009
SOURCE: Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Posted on Aug 20, 2009
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
Kenmore Elite model #11060992990, has suddenly gone haywire. First, the on button won't stay on--the machine starts, but as soon as I let go the button, it stops. When I duct-taped it to stay on, it ran,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore Dryers
Kenmore Elite electric dryer, no heat, runs if holding start ****
with this combination of problems it sounds like a power problem on the control board being you have more than one problem,it sounds as though you arn't getting a latch voltage at the relay energizing coils that latch the relays to power the motor and element
Apr 16, 2010 | Dryers
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Jun 14, 2009 | Kenmore 63942 Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite dryer
possible interface bd(front controls)there is a lot of electronics on the back side the relay bd on top left receives most of it's commands from front controls if your husband knows how to ck things pull bottom panel off there is a tech sheet on backside..may even ck thermistor on blower housing for correct readings
Jul 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
