Question about Kyocera Office Equipment & Supplies
We have a Kyocera FS C2126 with jamming problems
We have had this printer at the dealer for service twice, and they have replaced all rollers, provided us with a board for a more stable surface, and provided us with different paper. The printer still continues to jam intermittently.
  • 56 Answers
SOURCE: Kyocera Printer FS-1800 plus
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Posted on Nov 29, 2007
  • 39 Answers
SOURCE: Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Posted on Mar 03, 2009
rajeshpait
  • 542 Answers
SOURCE: how to deal with paper jam when there is no paper trapped/jammed
Check and clean the dust from the paper jam sensor.
Posted on Dec 03, 2009
  • 108 Answers
SOURCE: paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Posted on Jan 03, 2010
  • 233 Answers
SOURCE: how to i stop paper jams on kyocera ecosys
The first thing you need to do is open the device and clear any debris: leftover paper pieces, toner, etc. If this does not fix the jamming, the device could use a more thorough service. Inspect all of the moving parts and make sure that they are firmly attached. If it's possible to tighten down some components, a minor tweak with a screwdriver can work wonders.
Something a little unorthodox, but that has helped me in the past is lubrication. You could try lubricating the printer with mineral oil or paper shredder oil. There are two ways of doing this. You could open the machine up, locate rollers and then brush the oil onto the rollers. Or you could simply put a very then layer of mineral oil on a piece of paper and then run the paper through the machine. The first few pages out of the machine will have oil on them, but after a half dozen pieces or so, the parts should operate more smoothly and be less likely to jam.
I hope that helps.
Posted on Mar 01, 2011
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
How to open the fuser
You will need to open the cover on the rear of the machine to gain access to the fuser unit.
Jan 17, 2014 | Copystar Kyocera FS-C2126 MFP Printer
Open the fuser for FS-C2126 MFP
there is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
Jan 17, 2014 | Kyocera FS-C5030N Led Printer
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Kyocera fs-1920 paper jams when page is half way out of top , when you clear it the paper has some grooves in ? does not happen every time and when cleared it is ok again for 3-6 pages
on the menu buttons on the machine..change the paper exit to go out the back.. if this solves the problem.. you might be looking into replacing exit rollers or fuser
Mar 09, 2010 | Kyocera Mita FS-1920 Laser Printer
Paper jammed between 2 red rollers in the back, can;t dislodge
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Problem with printer kyocera mita fs 4000dn make anoise than intalled devoloper unit.
check the gear in the dev unit. also try and turn the mag roller by hand it might be jammed up
Jul 03, 2008 | Kyocera FS-4000DN Laser Printer
Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Feb 23, 2008 | Kyocera FS-4000DN Laser Printer
19 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
