Question about Car Audio & Video
How to bypass protect mode on MA audio hk 597
blueextc3221
  • 15935 Answers
SOURCE: my ma audio hk 4000
If there is no protection light on, be sure the input is on. Some head units need to be turned on manually (factory set to OFF).
Verify the subwoofers are wired properly.
A list of your components would help to solve your problem.
If it is new, it should still be under warranty - worst case scenario output transistor(s) blown, or power supply bad.
Posted on Jan 09, 2009
etirbynnor
  • 655 Answers
SOURCE: JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
Posted on May 27, 2009
etirbynnor
  • 655 Answers
SOURCE: my ma audio hk 898 will power on but will not push
Hello 76firebirdfo,
If there's no sound at all from the subs and you know they are good, there's probably no output from the amp. It's either wired incorrectly or it is defective.
If there's some sound but just not loud enough, then either the amp is not getting enough of an input signal from your head unit, or the amp settings are not adjusted properly. Adjust the crossover and gains for the best output to subs. LP filter on, crossover frequency at about 80-100Hz, and gain to maximum without distortion when head unit volume is at about 3/4 maximum.
Hope this helps.
Posted on Jul 14, 2009
  • 45 Answers
SOURCE: MA audio HK 12 competetion subwoofer, the 1500 rms
Fs is a thiele-small parameter, meaning resonance. You can use these parameters to simulate the woofer's bass response in different boxes etc.
http://en.wikipedia.org/wiki/Thiele/Small
Posted on Jan 22, 2010
  • 4234 Answers
SOURCE: HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Dan
Posted on Apr 06, 2010
Why Harman Kardo HK 3490 goes into DSP voltage protect mode
This amplifier can go into protection if one of the low ohm resistors on the power module that is soldered to the transformer is defect. Check out R951 and R952, they are both 0R47 (0,47ohm). They are often broken and measure some kilo ohms.
Apr 29, 2014 | Harman Kardon HK 3490
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
HK 3370 turned into protection mode after pluging in a playing iphone. Happened more than one hour ago but hk3370's power light is still red. How do I get this thing out of the protection mode?
turn unit off using main power button, hold down t-mon and cd buttons at same time as switching main switch on should power up and show reset on the display for a short time then dhould go to standby this has reset unit and should now be ok
Jan 10, 2011 | Harman Kardon HK 3370 Receiver
Dan
Apr 06, 2010 | Harman Kardon AVR 240 Receiver
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
My ma audio hk 4000 amp is powered on no sound coming thru subs amps brand new
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Technics amp su-vx800 goes in to protection mode after approx. 10 to 15 mins of play depending on the volume level.switch it off for 2 mins and it operates again.Could this be a faulty muting ic AN7073, a...
yes it can, it sounds like its over heating, make sure that your product is able to get fresh circulated / cooler air
if it already is, then it probably is a faulty product.
Nov 22, 2008 | MA Audio Hard Kore HK-898 Car Audio...
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
