Question about Bosch WFMC 3200 Front Load Washer
Put front gasket back on
I have a bosch nexxt wfmc 3200 uc washer adn we opened it up today and the rubber gasket and a spring loaded wire circle was off. I am having a hard time putting it back on, is there a trick to this? Does a certain area need to go on first? Any help would be appreciated.
matt
SAME PROBLEM: I have a bosch nexxt wfmc 3200 uc washer adn we opened it up today and the rubber gasket and a spring loaded wire circle was off. I am having a hard time putting it back on, is there a trick to this? Does a certain area need to go on first? Any help would be appreciated.
  • sessions99 Mar 15, 2009
    the door gasket whent again and now the retaining hoop is also off. What's the best place to get the parts and what is the trick to installing  the gasket/hoop
  • 27 Answers
Start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Posted on Mar 12, 2009
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Wire that holds the rubber gasket came off
can usually take to people if you are not familiar.the spring does down towrds the bottom of the boot in the middle of the boot start with the ring at the top and go down both sides the have someone hold it in place about the 10 and 2 o clock positions while you use your hands or small screw driver and finish putting the ring in place
Jun 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Wfmc 3200 fixed E04 problem, where does the gasket go?
Take the cap back off. Put some pipe thread sealent on it. Just some basic pipe thread tape should do the job.
Feb 13, 2009 | Bosch WFMC 3200 Front Load Washer
Replacing boot on Bosch Nexxt Front loader
are you talking about the thin wire closet to you... if you are, you'll find a small bend in the wire where you can pull it out. It is right next to a spring on the wire.
Sep 03, 2008 | Bosch WFMC 3200 Front Load Washer
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Front Door gasket and ring
no trick or technique - just a pain to do. don't be afraid to stretch it and if done as a two man job its far easier. one way i thought of was to make a former of approx the right diameter and slip the ring from the former on to the door boot
May 14, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
330 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
