Question about Heavy Machinery
Mighty mac vcb1100
Change belt
Tension adjustment on mighty mac chipper
Guessing you are talking V-belt tension.
V-belt adjustment rule of thumb is to tighten so that the belt will twist 90 degrees in the middle of the belt.
Make sure your belt isn't glazed and that your pulley are aligned. Place a straight edge from pulley to pulley and look for a gap on one side or the other of the smaller pulley and adjust so that the straight edge touches the face of both pulleys.
The manufacturer has very good customer service according to what is out there.
Here's their site -
Mackissic Chippers
Sep 24, 2017 | Heavy Machinery
What is the torque for installing the crankshaft for the 2.4 mitymax motor?
Mitsubishi Mighty Max crankshaft bolt Questions & Answers ...
www.fixya.com > ... > crankshaft bolt > Cars & Trucks > Mitsubishi
Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
Oct 02, 2015 | Cars & Trucks
How to change the water pump 1990 mitsubishi 2.4 l mighty max
When you change a timing belt or water pump--you do both
In some cases you get new idler pulleys as well & may need
new tensioners
Go to You Tube Video & watch the video of your engine type
Dec 06, 2012 | 1990 Mitsubishi Mighty Max
We cannot locate the manual for our Mighty Mac Chipper/Shredder, 7hp Briggs & Stratton motor. Can you either send a copy in the mail or by Email at jc_marriott@yahoo.ca? MIGHTY MAC CHIPPER/SHREDDER,...
Don't know where you can get a manual, you never stated the model number, but you could contact the factory and talk with an engineer about whatever problems your having. (There are also parts still available for these older fellas).
http://mackissic.com/Tech%20Support.html
Jun 16, 2017 | Garden
How do you change the alternator belt? the belt that spins the fan to keep the engine cool?? trying to replace it, can't figure out how.
release all the bolts to the alternator so that is able to swing inwards,then refit belt,using the alternator to pull belt tight.......check belt after tightening alternator to make sure its not too tight.
May 24, 2010 | 1988 Mitsubishi Mighty Max
Changing air conditioning belt
2002 Mitsubishi Montero Sport: How do I change the airconditioning belt, and a configuration picture too?
Nov 14, 2009 | 1989 Mitsubishi Mighty Max
1991 Mitsubishi Might Max Timing Belt
timing chain when you get a variance in timing easy to see with a timing light haynes manual should be sufficient
Jul 21, 2009 | 1991 Mitsubishi Mighty Max
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Heavy Machinery Logo
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
