Question about HP PAVILION M1072N MEDIA CENTER - P4 530 3.0GHZ - 1GB RAM - 200GB - DVD-RW - CD-ROM HP PC Desktop
Windows not loading
I turn on my pc and a blue screen appears with hp logo in the middle and otions to acssess the boot menu, setup and system recovery this stays on my screen and nothing else happens. i try to go onto one of the options eg boot menu but nothing happens i have no recovery disks as system recovery is built in but i cannot acsess it
  • Veli Kerim Celik
    Veli Kerim Celik May 11, 2010
    In which way can you not you acces the built in recovery? Does it come up with a error message? Or doesn't you know the key to press?
  • 76 Answers
Sounds like you have a nasty virus that has corrupted your harddrive
so that means that the recovery portion is corrupted as well
you need the operating system and reinstall everything
Posted on Mar 12, 2009
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Black screen, Blinking cursor for 25-30 seconds after HP logo at cold boot.Restarting PC does not add this extra step before windows startup screen. Booting from power off condition has this condition...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 02, 2011 | HEWLETT-PACKARD Hewlett Packard HP ENVY...
I have a dell inspiron 1545 and i need to format the hard drive how do i do it
Hi there are 2 Ways to Do it. You Choose .If this is the first time you are trying to do it on this 1545 if it was never formatted in the past use Method 1 if it was already formatted once in the past then use method 2 because method 1 wont be available. Method 2 is lengthy process.
Method 1 : Restore the computer's software to original condition.
Using Dell Factory Image Restore in Windows Vista
new_notice.jpg Notice: Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
__________________________________________________________________________________
Method 2: Reinstall the operating system from the OS Setup Disk. For Windows Vista
1 Insert the Windows Install DVD into the DVD drive, and then restart your computer. When the message Press any key to boot from the CD or DVD ... appears, press a key to continue booting to the DVD.
new_note.jpg Note: If the computer does not boot to DVD, follow these instructions. If it does boot to DVD ignore this note.
1 Power on the system and watch for the Dell logo to appear.
2 When the Dell logo appears, press the key to load the Boot Menu. If the menu does not appear, restart the system and tap several times at the Dell logo screen.
3 When the Boot Menu appears, highlight the CD/DVD drive (listed as "CDROM", "CD/DVD" or "CD/DVD/CD-RW") entry from the list and press .
2 After Vista Setup loads, confirm the Language, Time, Currency and Keyboard Method settings are correct then click Next.
3 On the Windows Vista Installation page, click Install Now.
4 Review the terms and click I accept the license terms to proceed.
5 On the Which type of installation do you want? window, click Custom (advanced).
6 On the Where do you want to install Windows window, make sure the largest Primary Partition is selected then click Next. If the Primary partition has 0GB free, there should be a separate line for Unallocated Space. Select this unallocated space and click Next.
new_note.jpg Note: Your computer will restart several times during installation.
7 When the Setup window appears, select a user name, password, and picture for your user account.
8 On the next couple of screens, use the default or recommended settings prompted and click Next until you see the Time & Date screen.
9 Click to select your time zone then click Next.
10 After the Thank You message appears, click Start.
If you need more details go to this page Source from Dell support site
How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Feb 04, 2011 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
When you first start your computer how do get it to read the disc first?
You go into Boot Menu, and set the - first boot device to CDROM.
The computer will then read what is in the optical drive, first.
Computer off, press the Power On button. Watch closely for the blue dell logo.
Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
At the top right of the screen you will see F12 = Boot Menu.
This screen goes by F-A-S-T!
As SOON as you see the blue Dell logo press the F12 key.
If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
This will restart your computer so you can try again.
Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
The Boot Device Menu has the devices listed, and each device has a number next to it.
At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Left-click on - Entering System Setup
Should you have any questions concerning this, simply state so in a Comment.
May 03, 2010 | Dell Dimension 4700 PC Desktop
Error loading operating system
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
Boot failure at USBd checkpoint
There are 2 steps you can do to fix the problem
1. Change the USB Emulation Setting in the BIOS
NOTE: It is recommended to disconnect any USB devices before performing the following steps.
Restart the system.
Wait until the Dell Logo appears.
At the Dell Logo screen, press F2 right away to enter the System Setup.
The System Setup screen will appear.
Press the down arrow key to highlight Integrated Devices (LegacySelect Options).
Press Enter.
A small box with a list of devices appears in the middle of the screen.
Press the down arrow key to highlight USB Emulation.
The default setting is On.
Press the Space Bar on your keyboard to change the setting to No Boot.
Press the Esc key.
The small box disappears.
Press the Esc key again.
A small box with list of options appears in the middle of the screen.
Make sure that Save Changes and Exit is highlighted in blue.
Press Enter.
The system will then restart.
The recommended changes have now been made to the BIOS.
2. Reset the Dell Dimension desktop System Setup (BIOS) to factory defaults.
Restart the system.
The Dell logo screen appears.
Press F2 to enter the System Setup (BIOS).
The System Setup screen appears.
Press the ALT + F key combination.
Press the Esc key to Save and Exit.
Press Enter to Save changes and exit now.
The BIOS is now set to the default settings.
Apr 02, 2009 | Dell Dimension 3000® Pentium® 4...
Windows xp logo will start to load then......
To solve this will require more information from you. The Blue screen is Windows way of telling you that it has a driver issue with a basic component, usually your video card. Did you recently make any hardware changes? If so please let me know what was changed.
When windows first boots, you can repeatedly press the F8 key until you see a menu giving you choices of windows booting. You need to select Safe Mode. Safe mode should allow you to at least boot without a blue screen. The blue screen could also be cause by a virus or other software.
Microsoft has a description of Safe mode here;
http://support.microsoft.com/kb/315222
but here is a quick snippet
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 13, 2008 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
